seat ideas
have any cheap seat ideas? both of my leather seats are ripped and cracked
94 Subaru SVX FWD 51k 04 Mazda B4000 (work truck) |
Re: seat ideas
Could buy some "racing" seats from ebay. They come from china..
Like these: Click HERE Look like this: They're cheaper than OEM and some out of an STi and they weigh a lot less..
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k At least it's going down..
Re: seat ideas
they will fit and everything. i got power seats too. will the bolt holes fit and everything.
Re: seat ideas
These ones aren't power which is what makes them considerably lighter but they move manually.. They don't fit directly in so you have to mock up your own brackets to make them work. If you don't know how, I'm sure someone here could walk you through it.. Any novice welder could technically do it.. Sometimes you may not even have to weld at all, just make some slight modifications.
Re: seat ideas
you could get new hides from motorsport warehouse. Also saw another company highly recommended recently. Will look again if you are interested
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
Re: seat ideas
Someone just recently posted about putting in some JDM WRX Sti seats. Looked real nice and bolted in without too much trouble, as I recall.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
Re: seat ideas
jjanak, those seats are good, worth the price compared to branded names, but they need a little work.
I have them installed in my car as you can see HERE. The good thing about them is that they are light and comfy. The bad thing is that as you can see from the ebay Ad, the rails lock on only one rail and not on both. While accelerating and braking, you can feel your body spin counterwise to force of what you are doing Currently: I fabbed an adapter bracket for them to fit. The seats are screwed onto the adapter and the latter fit the OEM bolts of the floor. Future plans: I bought OEM rails from an L model SVX. Those rails are manual, both and they lock on both sides, so I will be refabbing adapters that mate the OEM rails to the seats. I bought OEM gray leather skins, 1 complete (F+R) + 1 more R. I am planning to refresh my interior leather since you can feel it dry currently. I am talking here about the rear seats' leather. As for the fronts, the Chinese ones that I have right now, I am gonna use the OEM front seats + rear seat skins to re-upholster them. The tips of the seat, where there is change in color, i am thinking about the same material of the faux suede What do you guys think?
Re: seat ideas
To all, seats are a safety item and as such brackets to mount them should be built well to absorb the loads in the event of an impact and keep the seat in position. Please keep this in mind when buying and installing aftermarket seats. Todd
Down to none |
Re: seat ideas
The leather setup that dayle sells looks amazing, I admit. There is a problem there. They're so damned expensive! If your looking to go down that road and just want to make your stock seats less ugly, I say go to a local upholstry guy and have him give you a quote.
Now if you want a lighter car and possibly more comfortable, and better looking (in my opinion) seats and don't mind some work, I say go with either the Chinese ones or the STi seats.. The only problem is that the STi seats are expensive as crap on eBay so if your going to go shopping for then, check for used ones on the STi forums. Some of them are stingy with their seats and try to milk as much cash as possible but I'd start with a low offer, wait till they're in need of cash and offer again. Just as well, you may be able to find some at a local junkyard even..
Re: seat ideas
for saftey reasons stick with oem or name brand aftermarket
the ebay seats are not crash tested and will most likely fall apart in any kind of accident |
Re: seat ideas
Just don't get in an accident!
Re: seat ideas
If you go with STi seats, my vote is to go online and get some older gc8 ones. The newer Impreza seats sit so high that you'll have to make custom brackets. The differece between 99's to 05's is crazy, like, solidly 5 inches taller. As it is, the older ones still sit a tiny bit higher than the stock SVX seats. With the seats I did, I still had to do some cutting and welding, but its not too bad if you're patient. I agree though, older STi seats are the way to go if you can find them cheap.
As for the ebay seats, some are good and some are bad. If you've got a pair of sliders that will work, the rest shouldn't be too bad. |
Re: seat ideas
See I was going to go with the older ones as well but they're... cosmetically challenged compared to the newer STi seats..
Re: seat ideas
I find the 2008 STi seats more comfortable than the 2006 model. But the stock SVX leather seats are more comfortable than any STi.
I spent the whole day today sitting in a Nissan GTR. Those seats are not comfortable at all.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
Re: seat ideas
http://www.subaru-svx.net/forum/show...577#post640577
I wouldn't exactly call these cosmetically challenged or uncomfortable Yes I'm biased, I love these seats. I'm not saying it would be that hard to make a cheaper set of ebay seats work fine. I just think that the gc seats are the easiest to fit without getting really custom. |
Thread Tools | |
Display Modes | |
