stupid stereo noise!
Hey guys. I have an aftermarket system consisting of a clarion deck, two jbl amps, and a crossover. Two pairs of RCA's running to the back... when i plug in the Monster Wire RCA's (a lot heavier shielding than my Stinger hyper series), i introduce engine noise into the system. And i do mean engine noise. When the deck is muted, it is so damn loud!!! On an unrelated note, i upgraded to a different amp, so i know it's not the amp that's doing it. My guesses are either the crossover or the RCA's... but this didn't happen in my RX7. There was absolutely no engine noise in the system at all, and i had the same exact components. Is there anything that i could inspect? Perhaps a bad ground somewhere? Where? Should i re-do the grounding for the alternator?
Thanks guys -Ross |
Ground is an important task.. start with the amp ground, then alternator.. some alternator do produce noise also.. Could it be the head unit?
your grounds should be as close together as possible. try a ground loop isolator, because its easy to put in (RCA connectors), and if that don't work, maybe try a noise filter on the power lead.
Alan 1987 928 S4 (Black) SOLD! 1997 SVX LSi (Ebony) SOLD! 2005 Legacy GT (Silver) [Cobb Stg 2+] SOLD! 1987 928 S4 (Black) SOLD! 2005 Forester XT Premium (Crystal Gray Metallic) SOLD! 2008 Lancer Evolution X MR (Apex Silver) [Cobb Stg 1+] 2015 Outlander Sport 2.4GT AWD (Mercury Gray) 2013 G37xS (Obsidian Black) |
nope, not the head unit or my equipment. its either the car, or the wiring in the car. It's 4 gauge wiring running on the driver side and two pairs of rcas running on the passenger side.
noise only occurs when the engine is running. I'm thinking its the grounds, so i'll re-do those. The alternator sounds like a valid reason also. |
fix
Get a good quality filter/choke on the power feed for all your audio equipment. The SVX alternator is REALLY noisy! I have seen/heard static inverters that generate less RF noise than my alternator!
Good luck
-- Chris Founder/Administrator SVX World Network ECU Tune (stage 1), PWR (prototype aluminum radiator) Amateur Radio - General Class - K7SVX #1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed) #2 92 Teal LSl 125k (Retired, car rescued from a field of weeds) 2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver) 2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler) 1985 Honda VF500 Interceptor (fair weather fun commuter) Going on 11 years of NHRA bracket racing NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com) 2000 1st Place Club Challenge Series 2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway) 2003 4th Place Season Track Champion, Import Racing (Firebird Raceway) 2003 1st Place NW Regional Import Shootout (July 5th) 2004 1st Place Club Challenge #1 (Firebird Raceway) 2004 1st Place NHRA "King of the Track" race 2004 NHRA Gold Cup 2nd place season win 2004 Import/Sport Compact 3rd place season win 2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC) 2007 1st Place Import Survival #3 2007 1st Place Track Champion Import Summer Jam (Wild Street Class) 2007 1st Place Import Survival #5 2008 Club season 1st place win, Club Champion 2008 2nd Place Season Import Final. 2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or) 2009 2nd Place Import Summer Jam (Wild Street Class) 2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2 |
I'm thinking that it could be the alternator as well. What is your stereo setup?
I noticed interference with my Alpine setup. My alternator died 4 months after install and I don't recall hearing the noise after I had the alternator rebuilt. I'm going to have to take another listen today to be sure. Fortunately the interference I had wasn't all that bad.
Well... setup is as follows
optima yellow top 4 gauge running to the back through a 4gauge into 4-8 gauge split from the 4 gauge at the distro block is a lead to a capacitor and a jbl1200.1. Both the cap and jbl1200.1 are grounded at the trunk latch with all of the paint stripped with a grinder. Off the positive distro block is a 10 gauge running to a JBL 80.4 (used to have a 2 channel alpine, with the same exact results). The 4 channel is grounded at a different location using a 8 gauge wire running to a ground distro block with 10 gauge running to the amp, and another 10 gauge running to the kicker x3i crossover. I had this EXACT setup in my RX7 and no problems. I'm thinking it's the grounding point where i grounded my distro block for the 4 channel. As for the rca's... one pair is a stinger hyper series (blue translucent) and the other is monster cables... those are MUCH thicker than the stingers. It gets alot worse with both pairs of the rca's are plugged in. It's not that bad when one of the two is plugged into the crossover. It's a clarion 7575 deck with 4 volt pre-out. OH YES!! Important fact: when i hit bumps on the road, SOMETIMES the noise diminishes to an almost unnoticable level. Carrying on.... I think it's the grounding point for my 8 gauge distro block. Perhaps its inadequate ground for the jbl 80.4? Thanks guys! |
I FIXED IT!!!
Alright... so what i did was replaced the wire from the chassis to the ground distro block with 4 gauge. also changed the wire from the block to the 80.4 with 8 gauge. It sounds AWESOME. There is still a faint hint of engine whine, however... possibly due to the noisy alternator. Any fixes for this?
-Ross PS: i have some left over 4 gauge, and four 4-gauge ring terminals. Perhaps i should re-ground the battery and engine block? |
Thread Tools | |
Display Modes | |
