Old 05-09-2009, 04:02 AM
Dessertrunner's Avatar
Wiring for manual gearbox on Oz, JDM & European Cars.
Okay a couple of guys have contacted me to help sort out the wiring on there cars. Most of the cars outside of the USA are wired different so they need to be sort out differently. As I see it these things need to be worked out if I have forgotten please speak up.
- Starter.
- Speedo.
- Cruise Control.
- Reverse light.
Is that what everyone needs.
Tony
Old 05-09-2009, 04:25 AM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
Re: Wiring for manual gearbox on Oz, JDM & European Cars.
all good to know, i am in need of the last 3 points, also thanks agin for doing this!
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
Old 05-09-2009, 06:11 AM
legacyau legacyau is offline
i will be interested one day soon
Old 05-09-2009, 07:21 AM
fluo fluo is offline
Hi guys,
Im also searching for the wiring. all i have is :
speed sensor wires, but dunno which wire is what : http://img17.imageshack.us/img17/6499/svxconnectorc.jpg
reverse light wire: http://img7.imageshack.us/img7/7795/rckfahr.jpg
greetings
Old 05-09-2009, 07:25 AM
Its me again!
here is the wiring of the european svx! there you can see, which wires the speedo has on the tcu.
http://muellertimo.privat.t-online.d...X-ATF-Docs.pdf
so white goes to tcu. black and yellow to an extra connector B69
greetings
Old 05-09-2009, 05:36 PM
JJ I hope you didn't wire the starter through the gear box netrual switch. The reason is that the gearbox switch can not take the direct current for the stater and will bur out.
Tony
Old 05-09-2009, 08:26 PM
I think it is best to sort out the speedo first so here goes, its very simple and can be done to a working siple level in about 2 hours.
The sender on the gearbox has the following wires:-
from the left with the catch or lump on the top of the connector. The first terminal needs to go to the postive power on the battery (later we will wirer it better), next terminal to the ground of the body of the car, the last is the signal wirer.
Okay locate the white wirer on the 16 pin terminal block terminal 15, second last bottom row right side of the plug. My wire is white with a slight black strip, that connects to the signal.
I will come back with the wiring under the dash in the next day.
Tony
Old 05-10-2009, 02:14 AM
Under dash wiring is as follows:-
We are going to cut into the old TCU plugs that were pluged into the unit. We are looking for the Black 20 pin & Black 16 pin under. On black 20 located pin 17 which is a white wire, on the Black 16 locate pin 6 Yellow Red.
Join the two wires together.
If you have done the rest right the speedo should now work. Hope this helps.
Tony
Old 05-10-2009, 07:45 AM
Hi,
ok thank you for your description. but works the sensor with 12 volts? i thought 5 volts or so. is the signal of the legacy mechanical speed sensor the same like the inductive svx sensor?
I have no information about the old legacy speedsensor wiring. Can I test each speed sensor wire of the legacy sensor with the svx connector pins , or could it destroy the ecu ?
Thank You
Old 05-11-2009, 02:19 AM
The sensor is 12v the output goes low or zero volts. Did you get the wire and plug with the sensor? If you do the wiring as I suggest you won't hurt the ECU. Give it a go.
Tony
Old 05-11-2009, 05:03 PM
-JJ-'s Avatar
Endangered Species
Tony
Not sure, E set this up, what do i need to look for as i will be all over this come the week end
Old 05-12-2009, 02:25 AM
Will the car start in gear? If so then the wring might be okay. Is there a relay under the bonnet?
Tony
Old 05-16-2009, 07:56 PM
-JJ-'s Avatar
Endangered Species
The car is garaged in The southern highlands and im living in sydney,
Wont be back down to work on it for a week or two, will post update asap
cheers,
Jake
Tony
Old 05-17-2009, 02:10 AM
JJ I will be away for 3 weeks so see you then.
Tony
Old 05-17-2009, 05:29 AM
Originally Posted by fluo View Post
Its me again!
greetings
Fluo
Thank you for the German diagram scan. That is very interesting to see.
From our research it would appear the German market SVXes were equipped with the ACT-4 gearbox.
See thread here:
http://www.subaru-svx.net/forum/show...any#post485067
UK, Australia/NZ and Japanese SVXes were supplied with the VTD gearbox. These markets were all RHD. In this VTD type gearbox the speed sensor signals both come from inside the gearbox, but with the ACT-4 type one of the sensors [SS2 I think] is fed from the differential housing and is the Hall Effect type.
The reason I mention this is because I would expect your speed signal to the speedometer to be coming from the additional wire beside the dip stick for the differential of your auto, rather than in the wiring loom [cord] running up the left side of the gearbox, as it would for the VTD type.
I hope I am making this clear enough. Assuming I am correct about your gearbox type this may imply but not guarantee that whatever speed signal re-wiring the US owners have done for manual gearboxes will also work for your German gearbox.
By implication what the Australian guys have to do to keep their speedos working may be a little bit different, becuse I don't believe their speedo gets the Hall Effect signal.
