Go Back   The Subaru SVX World Network > SVX Main Forums > Wanted or For Sale > SVX World Network Official Group Buys > Group Buys
Old 01-21-2009, 11:48 AM
Front Camber Caster Plate Group Buy
SvxRide has been working with Kmac out of Australia to get SVX camber caster plates for a while now. I was working with Bill in getting them to fit his car a short while ago. Now that they have been installed and are known to be working very well, we would like to offer a group buy on them. The group buy is more or less a way to save on the costly shipping of individual units from AU.
Pictures: Sorry if they are slightly out of focus
These strut mounts are VERY high quality and give the user adjust ability beyond what camber bolts can and make it so easy to do. Just jack up the front of the car, loosen (do not remove) the 3 studs. Adjust camber or caster to desired amount. re-torque the 3 studs... Thats it! these mounts are also much firmer than the stock rubbers, which in turn also increases suspension precision which can also help your constancy in handling.
The Group buy pricing is $399+shipping from NJ for a pair of front mounts.
Please feel free to ask any and all questions in this thread
Old 01-21-2009, 12:18 PM
shotgunslade's Avatar
Re: Front Camber Caster Plate Group Buy
I could use a pair.
Old 01-21-2009, 01:52 PM
Ok. list starts.
1. Shotgunslade
Old 01-23-2009, 10:49 AM
I would like to get at least 6 pairs to make the group buy go...
Old 02-09-2009, 07:03 PM
wawazat??'s Avatar
Yeah, I'm still around
hmmm, probably should add me to the list Tom
Down to none
Old 02-09-2009, 08:04 PM
Ok I probably will
1. Shotgunslade
2. Wawazat??
3. TomsSVX
Old 02-10-2009, 08:54 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
YT,
We can provide the stage 2 or stage 3 kit at the advertised price. I'm running the stage 2 kit on my car and I'm not sure I'd recommend the stage 3 for anything other than dedicated track cars (Dan?).
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 02-10-2009, 09:41 AM
sicksubie's Avatar
Why would you not recommend the stage 3 for anything less than a dedicated track car?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 02-10-2009, 09:56 AM
SVXRide's Avatar
There is no rubber/urethane to dampen road inputs to the car (and you thought that Gruppe N mounts increased "noise").
-Bill
Old 02-10-2009, 10:03 AM
Sov13t's Avatar
Sov13t Sov13t is offline
1. Shotgunslade
2. Wawazat??
3. TomsSVX
4. Sov13t
Can't miss a group buy...
-Sov13t.
Old 02-10-2009, 11:36 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
If only I had money
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-10-2009, 09:54 PM
Need two more people to jump on this so we can place the order
Old 02-11-2009, 07:12 AM
sicksubie's Avatar
again... if my pearlie sells I am in....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 02-11-2009, 08:02 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Add two sets. One for me and one for my son.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 02-11-2009, 08:11 AM
sicksubie's Avatar
If I do not get in with these 6 will I have to wait for another group of 6 to be put together?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
