The racer is almost a 5-speed
Over the past week, Ben has been slowly removing parts of the racer to prepare for the trans swap. Yesterday, I took the trans and all of Tom's swap pieces down to swap it in. The old auto came out real easy?? After a small issue with the flywheel bearing, everything started to go together.
By the time we had to stop working, the transmission and cross member were in and the linkage was all bolted up. Tom's kit is great, definitely makes the swap easier than doing the fab work yourself. Still left to do; - 1/2 the wiring - route the clutch cable - install the pedals - rest of re-install (drive shaft, exhaust, axles....) I should be getting down there again next week to help finish everything.
Keep us posted on the progress...
And I'll be interested in what she'll weigh in at now...
what did the racer weigh in at before the 5spd swap?
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
crap... totally forgot about the driveshaft I will drop that off to the shop on Monday.
Tom |
Tom don't worry about it. Dave found an outback with one in it that will fit with just the front end collar trimming. I think he's getting ya some rear ends too while he's there.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
Again, I can't say enough about Tom's x member. It was less than an 1/8 of an inch off from lining up on the racer. That is amazing fit and finish for a kit that isn't made via a computer. A quick 16 oz digital calibration aparatus lined the last bolt hole up perfectly. Only hiccups we've hit so far is I seem to have broken a computer chip/relay from under the dash, the pilot bearing was seized. Glad I checked it before installing it and the annoying fact that we're working in a 9.5x19 garage that has a spare engine in it, 6 tires lying around, boxes of motorcycle parts and all my tools. Our guess is she should be capable of a 13.8 second 1/4 mile if we find a pilot (NOT BILL) willing and capable of a decent launch at Reading. She's already done a 14.2 with 4.11 gearing at 75ish degrees. Running with our special 4.39 gears, 100 or so less lbs and a 5 should be more than enough to put it into the 13s.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. Last edited by benebob; 03-23-2007 at 02:56 PM. |
How exactly do you get 4.39 gears? and is that 2750 with the cage?
1988 XT6 FWD 5MT 220k |
Come on now, don't you want to know what it will do sideways in the quarter? -Bill
I wil pilot that bad boy if you want... I still need to learn my 6spd s/c launch for now too though. Should be fun. I already told Dave, I should keep at least 1 5mt shaft on hadn so I am still gonna get one made... If you guys need it, its yours
Tom |
Nice! Now, why will it only have 4 speeds? -Bill
"The racer has almost 5-speeds"
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? Last edited by Speedklix; 03-24-2007 at 09:46 PM. |
slingshot comming out of the hole if you do it right... this thing should cut a 1.6 60' and trap well over 100mph... Should be fun
Tom |
2600lbs? Nice one...
I weighed the rally car, with the cage and a boot load full of crap at 3000lbs...and was pretty impressed with that. Since then I've pulled the double firewall skin out which got a me a bit more and got rid of a few more things...including the pedals ! A decent cage should be about 100lbs or so. Matt |
