Old 03-05-2007, 05:45 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Cool, this eliminates the need of a big spoiler on the back of my car now
I wonder if those have silicon on the blades though? Where can you get those? Advanced auto or autozone?
1995 Subaru Svx L / AWD
Old 03-05-2007, 01:05 PM
AJ4U2's Avatar
AJ4U2 AJ4U2 is offline
Triple edge, silicone blades.. Almost 1 year old and still doing the job.
Old 03-05-2007, 01:44 PM
i still have the original wiper blades on my svx. the rear wiper, however, finally needs replacing.
Old 03-06-2007, 05:26 AM
msvx95's Avatar
It's just a phase
well....I would say I only replaced my rear wiper once just because I replaced the others. I mean who really uses the rear wiper that much?
Old 03-06-2007, 12:13 PM
Sid E. Ryner Sid E. Ryner is offline
Check out Dayle at Motorsport, he have PIAA silicone blades.
I had mine's for about 10 months and it works great and quiet.
sid
Old 03-06-2007, 09:28 PM
RedHotSVX RedHotSVX is offline
gettin there....
Send a message via AIM to RedHotSVX Send a message via MSN to RedHotSVX Send a message via Yahoo to RedHotSVX
Hello all....just thought I'd put in my $.02. I've had the Valeo's on my car for the better part of a year,Back when they were a whopping $29.99 each . And I replaced all three of mine and 3 on my wifes Odessey.
$180.00 in rubber!! However they are still quiet,and streak free.Even at high speed.There was one instance last week where some ice built up on the end of the pass blade due to it being lifted off the windshield in the rest position because of the curve on that side.So when it came time to use the wiper's,the pass side wouldn't clear all that well.But all in all,I think it was worth it since their overall condition is very good at this point.
And they have come down to $19 or lower since my purchase.
Mike....
8/96......Vin 100109
1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!!
Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines.
1997 SUS Legacy,finally got the engine in after a year!!
www.myspace.com/devilhornz
Old 03-06-2007, 09:50 PM
Hop Hop is offline
Classic SVX
Does anyone know how to remove the wiper arm? I'd like to take mine off to repint them. They're getting a little rusty.
Old 03-06-2007, 09:53 PM
At the base there is a little rubber cap, pry that out and you will see a 12mm nut. Once that is off, release the tension on the wiper spring and wiggle the arm.
Old 03-06-2007, 10:02 PM
Hop Hop is offline
Classic SVX
Alright I was looking at the first hinge of the wiper without raising the hood. I just went out and found the plug and the bolt. That'll make it much easier. Thanks.
Old 03-08-2007, 08:20 AM
Michael Blue's Avatar
Michael Blue Michael Blue is offline
Sold. :'-(
Originally Posted by RedHotSVX
Hello all....just thought I'd put in my $.02. I've had the Valeo's on my car for the better part of a year,Back when they were a whopping $29.99 each . ...
Did you notice these lifting the arm at all? Is there any problem putting them in the "summer" position? I have these on my wife's Audi A6Q and they lifted the arms significantly.
Thanks!
'92 Pearl White LS-L Touring SOLD
4.44 Swap, trans cooler, trans filter, trans temp gauge
Color-matched rear body and spoiler, X-drilled and slotted rotors, Axis pads, s/s lines
Raxles front axles
Old 03-08-2007, 06:50 PM
immortal_suby's Avatar
Thread Killah
I just put michelin wipers with the aero blade on mine. 1 rainstorm so far and they wipe pretty clean. I heard good things about them from people who are undoubtedly biased towards them :P We'll see if they last....
Locker Link
2015 BRZ Limited 6MT
Old 03-11-2007, 08:31 PM
nexus_7 nexus_7 is offline
Jamak's new uniblade SUCK. I tried them on both front and rear, and they are pathetic! I put them on my grandmas Escort and they are fine, but not for our windows. I have the michilan ones on my car right now, they are mostly good, but the passanger side still misses the edge near the bottom. I have the IONS on my Maxima and they are Great.
Old 03-11-2007, 10:44 PM
It's Just Eric's Avatar
Missing in action
I just put in a set of the formentioned michelin ones. they seem to work very well..they are quiet, chatter free and seem to get a good clean wipe. The only downside is where the blade will perch. Becasue it exerts equal pressure, the soft part of the blade deforms on the raised part of the stopper whereas the old type will sit on it without any problems. The result is a very slight 1/2 inch wide area that doesnt get wiped on only the downswipe of the wiper. Very minimal really, considering the benifits. More on them as the weather comes....
R.I.P Cool Signature.
Old 03-11-2007, 11:02 PM
+1 for the Michelin blades, as I was in Eric's car over the weekend. They're quiet and sleek. When I install a set on my car, I will be sure to adjust the position of the wiper arm so that it parks in summer mode without deforming the blade.
Old 03-12-2007, 04:33 PM
JaySVX's Avatar
JaySVX JaySVX is offline
I was wondering about the piece that attaches to the arm. It looks like there is a place for the blade holder to rest, but instead my bare rubber is up against it, and it's bending it. Does anyone know if there's a solution to that?
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
