Old 05-26-2005, 11:27 AM
alia176 alia176 is offline
DIY R12 to R134a conversion
I wanted to hear from the DIYers on this project. If you did your own R12 to R134a refrigerant conversion, what all did you end up replacing? I'd imagine you'd need to replace the dryer, replace the O rings, compressor oil and flush the system with a flushing solution. Are you changing the condenser as well to a larger one?
On the other hand, if I have a local A/C shop do the work, what kind of a price should I be expecting? The shop will need to evac the old stuff, remove the old oil, change the dryer and then recharge the system with R134a.
Does Subaru offer a conversion kit containing a dryer, O rings, etc.?
Thanks for any input.
Regards,
Ali
'92
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 05-26-2005, 12:20 PM
Rotorflyr's Avatar
Not specific to the SVX, but I have heard of people just putting the 134 into the 12 systems without changing anything, and having no problems (can't say as I would do it, just that I have heard of it being done)
2006 B9 Tribeca
Old 05-26-2005, 12:33 PM
I've heard of people doing that too but it's not proper. You should at least change the oil. I believe the R134 will leak out much faster without the proper o-rings.
Old 05-26-2005, 07:54 PM
JIMSVX's Avatar
JIMSVX JIMSVX is offline
.... what a sweet ride !!
Ali - Here's several Endwrench articles on retrofitting the '92 SVX (and other Subaru models) from R12 to R134, including Subaru Kit part-numbers and instructions:
http://www.ravensblade-impreza.com/t...nt/acretro.pdf
http://www.ravensblade-impreza.com/t...vent/retro.pdf
This is an Endwrench article that discusses the R134 refrigerant in general:
http://www.ravensblade-impreza.com/t...f/vent/134.pdf
Finally, here's an article on all the Subaru A/C systems that will probably tell you more than you ever wanted to know.
http://www.ravensblade-impreza.com/t...f/vent/ac1.pdf
- Jim
Old 05-26-2005, 08:03 PM
Chris's Avatar
Chris Chris is offline
Founder / Administrator
Send a message via ICQ to Chris
A product called HOTSHOT is made as a non-cfc replacement for R12. I have talked to people who have used it without problems. I am going to use in on my recently purchased SVX once I get a tranny in it. Will report my findings then.
-- Chris
Founder/Administrator SVX World Network
ECU Tune (stage 1), PWR (prototype aluminum radiator)
Amateur Radio - General Class - K7SVX
#1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed)
#2 92 Teal LSl 125k (Retired, car rescued from a field of weeds)
2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver)
2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler)
1985 Honda VF500 Interceptor (fair weather fun commuter)
Going on 11 years of NHRA bracket racing
NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com)
2000 1st Place Club Challenge Series
2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway)
2003 4th Place Season Track Champion, Import Racing (Firebird Raceway)
2003 1st Place NW Regional Import Shootout (July 5th)
2004 1st Place Club Challenge #1 (Firebird Raceway)
2004 1st Place NHRA "King of the Track" race
2004 NHRA Gold Cup 2nd place season win
2004 Import/Sport Compact 3rd place season win
2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC)
2007 1st Place Import Survival #3
2007 1st Place Track Champion Import Summer Jam (Wild Street Class)
2007 1st Place Import Survival #5
2008 Club season 1st place win, Club Champion
2008 2nd Place Season Import Final.
2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or)
2009 2nd Place Import Summer Jam (Wild Street Class)
2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2
Old 05-26-2005, 08:06 PM
comp_jas comp_jas is offline
I've done it on my Audi
I bought the WalMart Interdynamics conversion kit.
Unfortunately to do it right you need a vacuum pump and gauges. Can you borrow some?
The pump allows you to pull a vacuum on the system. This will boil off any moisture in the system. Water boils at a much lower temp in a vacuum.
The gauges let you confirm that the system will hold the vacuum (no leaks).
I did not replace any hoses, o-rings etc. It still has adequate charge two years later.
You might get by w/o the pump and gauges. I opened the system to replace the condensor. Source of my lost R-122.
Old 05-26-2005, 08:37 PM
JIMSVX's Avatar
- Jim
I meant to add that I had the conversion done by our local mechanic (who has done the conversion on other non-Subaru models.) He replaces the dryer and oil but no O-ring change. The cost was $230 and so far it's still putting out nice, cool air (he said with his fingers crossed.)
- Jim
Old 05-27-2005, 06:37 AM
Thanks fellas for the ideas. I'll review the endwrench article to get a flavor of what's up ahead. Chances are I may simply have it done by a pro but I like to know what is involved. I'm about to embark on replacing all seals up front so if the motivation is still there I might just start the conversion. But, I do need to have it evacuated by a shop to keep it environmental friendly.
I'll look into the conversion kit (92 svx kit p/n G31110PS000) cost and see if it's worth the effort. After evacuation, I can pretty much do everything except pulling a vacuum. I suppose I can rent a vacuum pump but we'll see!
Ali
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 05-27-2005, 07:05 AM
After not being able to hold a charge I took my SVX to a dealer he suggested trying the conversion, I alread spent $100 on the hard to get expensive R12 and the charge was lasting a week. The dealer changed all the valves and recharged it , that was 4 years ago for $150.00 I just used it last Sat and it still puts out cool air. ( not as cool as the original #311 I could have made jello on the front pass seat with that one. ) Still cold enough.
Old 05-27-2005, 07:32 AM
I went to Subaruparts.com for prices to come up with some numbers for the "kit" that the Endwrench article mentions.
KIt G3110PS000
Receiver/drier - $106
Suction hose - $152
Discharge hose - $152
O rings, PAG oil, R134a retrofit label - neglible
Total cost approx $410
Being a cheap bastard that I am, I'll just purchase the Drier and see what the local A/C shop wants to gouge me for!
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 05-27-2005, 08:31 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
I put R134a into my 6 last spring with just changing the low pressure side (the high wouldn't fit right and leaked so I left it off) valve. Nothing else as I didn't have a clue if it even worked to begin with and didn't wanna spend the time. Worked just fine. Did have to add about a 1/4 can this year. Definately not as cool as the SVX set up with my 95 but much better than before.
Old 05-27-2005, 09:54 AM
I am going to check with my Subaru Dealer and ask what they did to mine. Hey you could call them and ask. Center Subaru Torrington, Conn. Tell them Mr Lucky the guy with the White SVX , told you to ask. Ask for Service. I know I didn't pay any $300.00
Old 05-27-2005, 10:25 AM
I called my local dealer to see how badly they can rape me. They don't have the retro kit in stock so I told him that I'll supply all parts. All they have to do is perform labor. This is going to be good
Ali
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 05-27-2005, 10:59 PM
kuoh kuoh is offline
I just did this on my 92 and only replaced the drier and the two associated O-rings. The drier was only about $35 from Advanced Auto and came with the O-rings. The retro kit was an Interdymanics with a pressure gauge and 3 cans of R134+Oil. The 92's only had 21-25oz of R12 to start with, so you only need to fill it with 17-20oz of R134. At first, I didn't bother with evacuating the system and it seemed to work, but was somewhat intermittent. The next day, I took it to a shop and paid them $70 to evacuate the system, then refilled with the left over cans of R134 from the kit. It seemed to be more effective, but I didn't get a chance to really test it out since I had to go on a trip shortly after. All told, I only spent $150 or so and will be happy even if it only lasts another couple of years.
Kuoh
Old 05-09-2007, 11:02 AM
s'ko s'ko is offline
bump from the cellar
I was wondering how people's systems are holding up.
I have to get the AC recharged in my wife's 92SVX and i was considering going with a r134a conversion. estimate to recharge right now is 50 bucks labor and $90.00 per pound of freon.
Thanks
BW
