#451
-Chike
#452
I think it went a good 20 feet.
#453
Pictures will be coming soon. The system looks fantastic installed. Mike took pictures through out the installation both on his camera and mine. The pics on my camera are to be used for the installation manual. I'll post some of them in the next couple of days. I also wrote down the instructions as we did the install.
I think we've firmly established that the 2 wheel drive svx with it's open dif can't take the power of the stage 3 system. Mike's been planning on having his car converted to a manual awd, 6 speed i believe. He just wanted the stage 3 in this svx as opposed to his other because this one is cherry with low miles. |
#454
Sounds like a solid plan. How do u guys plan to get it out of FL though?? Glad to hear the systems are running properly
Tom |
#455
Sadly I'm paying for repairs to it, rather than hauling it home.
#456
Well Mike, you know who to talk to when you are ready to do the 6mt AWD conversion Good luck in the mean time
Tom |
#457
-Bill
#458
#459
Dyno?
So still no dyno data for the setup?
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
#460
No strips of rubber. The power never made it to the tires. That or the KDW-2's have gripping power than the strength of the diff. There wasn't even a churp, just a loud bang. |
#461
The "more power than the driveline can handle" isnt an exceptable enough estimate for you? There is no denigning that it makes power. I have done an accidentle nuetral drop when it was stock without causing any damage. This was just a flick to between 1/2 and 2/3's throttle. I think it's at least double the stock numbers. I do have the pre-modd dyno numbers if your interested in those. I believe they were a lowest pull of 171hp and a highest of 187hp. |
#462
#463
Ok, here are a bunch of pictures. I'm posting them as links since there are so many. There are a few steps left out by accident, namely the install of the tensioner but it's only two bolts.
the silver parts hung and about to be powder coated. http://www.ecutune.com/posts/run1/DSC_2656.jpg the silver parts powder coated and in the oven http://www.ecutune.com/posts/run1/DSC_2661.jpg the black parts hung and powder coated http://www.ecutune.com/posts/run1/DSC_2665.jpg the mass air meter wiring http://www.ecutune.com/posts/run1/DSC_2667.jpg We started the install by jacking the front of the car up and supporting it on jack stands. It stayed this way for the entire install which makes it much easier on the back and allows for easy removal of the fans and installation of the alternator. The driver's fan comes out easily through the top. The passenger fan comes out easily from the bottom. We then unbolted the power steering pulley and crank pulley with the belts still attached. Then we removed the belts, the pulleys, and the alternator. Then we installed the new crank and power steering pulleys. http://www.ecutune.com/posts/run1/DSC_2672.jpg Next the plugs are removed from the oil pump. Depending on the year of your car you may need a 12mm hex key from snap on. The new oil plugs with the bolt holes for the alternator bracket install with an adjustable wrench. http://www.ecutune.com/posts/run1/DSC_2676.jpg The lug on the alternator needs to be spun around so that it and the wire do not hit the oil pan. There is a spot on the back of the lug which aligns it in the factory orientation, this is ground off and the lug is put back on facing towards the other plug. The shaft it bolts to is splined so it will stay in the orientation which you install it. The alternator is then hung from the swing arm on the bracket and the bracket is hung from the new mounting holes. The bolt holes very exactly match the bolt pattern and the size of the bolts so it takes a second person to hold the weight of the alternator while bolting up the bracket. After bolting up the bracket the alternator is swung up to see where it hits the corner of the oil pan. A small dent must be put in the corner of the pan to allow the alternator to swing up all the way. This is easily done on the car with a smack of a hammer. http://www.ecutune.com/posts/run1/DSC_2685.jpg http://www.ecutune.com/posts/run1/DSC_2686.jpg http://www.ecutune.com/posts/run1/DSC_2690.jpg electrical connectors for 740 cc injectors installed. the wires are released from the old electrical connectors using a jewelers screw driver and slid into the new electrical connectors. http://www.ecutune.com/posts/run1/DSC_2700.jpg we then removed the airhose and throttle body http://www.ecutune.com/posts/run1/DSC_2701.jpg disconnected the fuel lines from the fuel rails and fuel hoses. unbolted the manifold http://www.ecutune.com/posts/run1/DSC_2704.jpg lifted the manifold off disconnecting vacuum hoses and electrical connectors in the process. http://www.ecutune.com/posts/run1/DSC_2711.jpg installed the new ac compressor bracket http://www.ecutune.com/posts/run1/DSC_2716.jpg Installed fuel rails with NISMO 740cc injectors and new fuel lines. Connected vacuum lines for vapor canister and egr. The egr is actually blocked off in the manifold and isn't necessary but the hope is that if it is left connected the sensor will not throw a check engine light since it is blocked off after the temperature sensor. The connection on the t off the block for the pcv system is blocked off. I will include the propper size bolt with the kit to screw into the T to block it off. We didn't have it so we epoxied it shut. The rest of the pcv lines are left connected to their original locations. http://www.ecutune.com/posts/run1/DSC_2717.jpg http://www.ecutune.com/posts/run1/DSC_2718.jpg http://www.ecutune.com/posts/run1/DSC_2726.jpg The throttle body adaptor, throttle body, iac manifold, bypass system, and airhose are assembled onto the supercharger outside of the car and then dropped onto the engine as a unit to which the rest of the hosing and electrical connectors can be easily attached before installing the manifold. http://www.ecutune.com/posts/run1/DSC_2739.jpg http://www.ecutune.com/posts/run1/DSC_2744.jpg The manifold is then test fitted into place in order to get the supercharger lined up correctly before putting sealant onto the flanges. It is then removed again, sealant is put on the flanges, and the manifold is installed. The belt and throttle body cover can then be installed. http://www.ecutune.com/posts/run1/DSC_2746.jpg http://www.ecutune.com/posts/run1/DSC_2755.jpg A small extension with a bent connector at the end must be bolted to the end of the main alternator wires and then covered in electrical tape. The second electrical connector reaches without any extensions. http://www.ecutune.com/posts/run1/DSC_2758.jpg http://www.ecutune.com/posts/run1/DSC_2762.jpg |
#464
Anyway, cool write up. |
#465
Regardless, once my set is sent to me I will be dynoing it. My car is stock and in absolutely perfect running condition so I believe my car will be a perfect canidate for showing power gains. I do believe though that adding a good exaust system with this setup will probably provide for 20+ hp but that will be the next mod after the kit is installed.
