which wires to splice for the manual swap
hi
Lets see..If I remember right reverse lights are red and red/white tracer. connect those to the black with black/green tracer... look on the auto and find the revers light sensor check the wire colors, thosr are the ones you need on the plug in the car. the clutch switch wires you need to connect are the black and black/white tracer connect those to the clutch switch that is a closed circuit when the clutch pedal is depressed. This is from memory hope this helps. I didn't do anything with the NSS switch on the transmission. |
Hey there you!!! Just saw that you have a "spec stage 2 Kevlar clutch".... You Have to get rid of that thing!!!! I had a kevlar clutch and it was the worst thing ever... Just get a good Organic disc... They work fine and are smooth as glass
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
There are two sets of wires going to the 4EAT. One is terminated with a 15 pin plug. You can ignore that one and tuck it up in the cabin of the car. The other set of wires terminates with a 12 pin plug. Pin 9 (green/red) and pin 10 (brown/yellow) get wired to the reverse light switch on the tranny. Pin 11 (black/white or blue/white) and pin 12 (black/yellow) get wired to the clutch pedal.
My clutch is nice and smooth when I drove it, While breaking in it shudders alittle until the surfaces "match" it shudders more when it gets wet from the hole plate missing too I'll see how it is when I get 1000 miles on it. |
thanks
