Old 01-21-2006, 10:16 AM
seasvx's Avatar
seasvx seasvx is offline
CD broke inside the player
when i stopped for coffee this morning, i left a CD in the OE Panasonic player and closed the cover. came out, started the car and heard the CD trying to eject behind the closed cover. this has happened before and i've managed to get the cover open, which results in bending the CD down severely as the cover drops. every other time, the CD would felx enough but this one broke. i ended up with about 1/3 in my hand and 2/3 of the disc still in the player. that part is apparantly not in contact with the transport mechanism 'cause it makes noise like it's trying to eject but can't grab the remainder of the disc.
i did searches here using several different search parameters and read the process for removal of the entire unit but i didn't find anything about how to extract this piece of broken-off CD.
anybody got a method to sneak this thing out w/o having to do the whole de-install process? i'd be grateful for a workable answer.
Old 01-21-2006, 10:26 AM
Can you use the broken part of the CD to attempt to rotate the piece still in the player? That may give the rollers enough grip to pull the rest of it out.
Old 01-21-2006, 11:32 AM
SubaSteevo's Avatar
No longer blue member
Rather than using the cd part (which I think it would be easy to also lose inside the player), I would suggest trying to use a paper clip.
-Steve
01' MSM Lexus IS300
Old 01-21-2006, 12:02 PM
Time for a new CD player.
If not, time to leave the hatch open while it's on? I never close it.
Old 01-21-2006, 12:07 PM
I never leave mine open. I'd rather people not know what kind of stereo I have in my car.
Old 01-21-2006, 12:09 PM
Manarius's Avatar
Manarius Manarius is offline
Tweezers? No, seriously.
-Jason
-Obi Wan Kenobi
Old 01-21-2006, 02:22 PM
If it's parked though there is no chance of the CD randomly popping out and getting stuck.
If this is a problem with the CD player I would just leave it open while the power is on.
Old 01-21-2006, 02:44 PM
wynndi's Avatar
wynndi wynndi is offline
Send a message via AIM to wynndi Send a message via Yahoo to wynndi
Needle Nose pliers worked for me when I snapped one. If not, low-profile tweezers ought to do it.
Dave W.
______________________________
1996 Redd
Old 01-21-2006, 03:33 PM
If you don't get it out by tonight (meet) I will have my sledge hammer along.
No, not hit the player, but to flatten out your hand so you can reach in to get it out.
Old 01-22-2006, 10:34 AM
RedHotSVX RedHotSVX is offline
gettin there....
Send a message via AIM to RedHotSVX Send a message via MSN to RedHotSVX Send a message via Yahoo to RedHotSVX
Try using a credit card.....while pushing the eject button,insert the card into the cd slot to see if you can feel the cd,then try sliding the card across the opening.Maybe the broken portion of the cd is not inline with the eject mechanism,and sliding the card across will move the cd so it will catch
Mike....
8/96......Vin 100109
1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!!
Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines.
1997 SUS Legacy,finally got the engine in after a year!!
www.myspace.com/devilhornz
