Old 09-25-2002, 08:33 PM
Originally posted by Ron Mummert
While we're here - can cryogenic rotors be "turned", or is this a REALLY stupid question?
Ron(duh?)
there aren't any stupid questions, just stupid people they need to be turned with a cryo-frozen lathe. ok, really, i don't see why not, but i hope they never need it.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 09-25-2002, 08:37 PM
Originally posted by Beav
From what I've read Ron they can be turned. Supposedly the freezing goes 'to the bone', so to speak.
At first I thought they might be on to something, but the more I think about it the more I think that they're probably as good as placing magnets around your gas line. I guess my biggest problem is that warping is caused by density variations and freezing isn't about to cure that. A better process in casting them would be the ticket. But the manufacturers are selling them like hotcakes at ridiculous prices already, why should they change anything?
i saw a show on cryo-freezing (Discovery Channel?) a while back, and its not a gimmick. i don't remember a whole lot from it, but people were freezing whole engine blocks, rifle barrels, etc. the freezing packs the molecules in tighter making the metal denser and harder.....or something like that
Old 09-25-2002, 08:46 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I can agree with that, however the warping comes from density variations in the rotor. As it heats and cools the denser portions are slower to move than the not-so-dense portions. The molecules may be more tightly packed, but they will still be denser in some areas. That's why I'm reluctant to buy into them, at this time anyway.
Old 09-25-2002, 08:53 PM
Invisible avatar
Talking
So you're saying the warpage problem isn't really cured; it's just a "higher quality" warpage. That settles it. I'm going back to drums at all 4 corners.
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 09-25-2002, 09:05 PM
Beav's Avatar
Not as old as Randy
Well let's just say IMHO that freezing will make them tougher and less prone to wear from harsh friction materials. The best I can speculate on the warpage issue is that they may be more 'warp-resistant' than 'warp-proof'.
BTW, the NASCAR set used drums for a long, long time - even after disc brakes were mature products.
Old 09-25-2002, 10:25 PM
Beav -
So what's wrong with placing magnets around your gas line? I get 150+ more Horse Power, and 10 more miles per gallon! You should see what happens when I put them around my rear view mirror!
Old 09-25-2002, 10:40 PM
Beav it appears to me that warping problems started with the advent of ventilated discs (rotors) and solid discs did not warp the same. Your explanation in respect of variations in density or cross section causing uneven heating and cooling adds up in every respect.
Forty years ago I raced one of the first disc brake equiped cars and the brakes were outstanding in all respects. On a dull day they could be seen running dull red. Absolutely no problems with warping and no brake fade but I must say that the rotor diameter was adequate in relation to the weight of the car.
Old 09-26-2002, 08:53 AM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
Yes, Cryo rotors can be turned. I've had to do it.
The theory behind cryo treating them is that it changes the molecular structure of the metal, that somehow it creates a more dense and consistant material. The consistancy I think is their claim to the reduction of warpage. I'm no engineer, so I can't explain it better.
My cryo rotors warped because my calipers started to stick. Calipers have been rebuilt, rotors have been turned, and for the first month, there's no warpage. Then it started to rear its ugly head again. It's a minor pulsation at this point, and only when the rotor is hot, and it hasn't gotten any worse. Oh well.
VK
1.3 cents
Old 09-26-2002, 11:00 AM
dromano's Avatar
dromano dromano is offline
ceramic rotors
Originally posted by Landshark
i'm looking at a picture of a 962c factory racecar right now and it has "drilled"(cast hole) rotors. those idiots - what are they thinking!?!?!
the new rotors on the 911 twin are ceramic - don't know if they use them for factory racing, though. i'm guessing yes.
The ceramic rotors reach 200 degrees at the hottest. The rest of the heat from braking transfers to the metal in the calipers and connected parts.
www.movit.de/rahmen/ceramic.htm
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 09-26-2002, 12:44 PM
mattski mattski is offline
I saw some highlights of a road rally on Speed channel and portions of the race were at night. They showed some Subies with an interesting wheel "mod". They were lit up by glowing red rotors.
That has to be over 1000 degrees F!
Kelli, this is even better than your neons.
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 09-26-2002, 08:31 PM
SVX_MY_BABY's Avatar
Beav, don't know where you are getting your quotes, but Dean at ART got me my rotors & pads substancially cheaper than OEM even after shipping from California and Customs clearance.
As an aside, I had gone through 2 sets of front rotors after about 79,000 km (Yes, I like to drive hard on the twisty roads which abound here plus the salt used on our winter roads rusted them badly.) I now have 30,000 km & 2 winters on the cryo's & they seem like new. Pads are also looking good.
Old 09-26-2002, 08:58 PM
Beav's Avatar
Not as old as Randy
Wrong context. I was referring to the ridiculous amount of money required to buy a seven pound hunk of cast iron. (o.k., maybe more, maybe less) Rotors are a long way from rocket science, but one would never know, considering their price. I wasn't singling out frozen rotors, I was referring to all rotors.
Old 09-26-2002, 09:24 PM
Invisible avatar
Talking
[QUOTE]Originally posted by Beav
[B]Wrong context. I was referring to the ridiculous amount of money required to buy a seven pound hunk of cast iron.
How 'bout the bucks spent for a dram of crytallized carbon that serves the purpose of making Ronnie Mervis a veddy happy campaah? Ever try to stop an SVX with a pinkie ring? Ah... The Human Condition. Gotta' marvel at it every day.
Ron.
'01 Miata SE - 79K
Old 09-27-2002, 05:46 AM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
nAScar is also still using carburated pushrod engines! nAScar is funny if they were only real cars instead of shells it might actually be interesting, not to mention 500 miles of all left turns gets boring after lap # 3
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 09-27-2002, 01:17 PM
$VX
haha. True that. Nascar blows. Plus, if you kick too much ass, they ban you (Charger Daytonas, Superbirds). >:|
- Ca$h
