Old 05-11-2011, 12:39 PM
Cam Cam is offline
Re: What are these for?
It is definitely three rows...
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 05-11-2011, 12:47 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Too wide for VGA: 5 pins x 3 rows. This looks like (reflection over) 8 over 7.
Old 05-11-2011, 02:46 PM
thumper_svx's Avatar
thumper_svx thumper_svx is offline
Either committed, or should be
Send a message via ICQ to thumper_svx Send a message via Yahoo to thumper_svx
Um... this isn't a '94 pearlie is it? I ask because those cables are exactly the same as a set I ran in my '94 pearlie for a car PC install that I tore out when the car left my charge... but I do remember leaving the cabling intact.
The d-cable you're looking at is an old "game port" joystick connector. I used an extension cable to the trunk because I was going to use it as my primary input method for a keypad that was mount on the center console. Some of the pins were going to be broken off for the display (serial, text only), some for the keypad and two more to run into the audio-in connector. Was trying to minimize cabling.
The other connector was an extended floppy power cable to provide power to the display.
Of course, details of my install were published online (carpc.net back in the day...) and I know several people who used my setup as a starting point. I know for a fact that at least two other SVX's got the same config as mine because I got emails about the installation. But damned if that audio connector doesn't look just like the one I had run out of my (then Blaupunkt) head unit.
Ich bin ein SVXer wieder
My Rides:
Red 1996 SVX LSi (Saffron)
2007 Yamaha FJR1300 (Kaitlin)
Previously owned; green '95 L AWD (sold), black/pearlie '94 LSi (too many problems), Polo Green '96 SVX LSi (apparently notThe end of an era)
Member #2 in the Yahoo! club, been here since the beta-testing days. In dire need of a cheaper hobby.
Old 05-11-2011, 02:52 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
It's a 92. There ARE pins broken off..but the car is from Washington..but the lady who owned it before my friend(washington) was from MO...
Old 05-11-2011, 03:04 PM
LOL... well, not mine then But possibly from someone who took my design and ran with it?
I've not seen anything like that in a stock SVX. Seriously, I'd try to trace that black cable back and see where it goes. If it is part of the old cell pre-wiring... well, I don't know if any of my cars had it and I don't have my '96 on hand right now to see if it exists there at all.
My Rides:
