A/C Compressor sometimes does not turn on
Just had the system completely vacuumed and refilled - When the compressor turns on, it works great. But about 1/4 times, it just will not engage until about 15-20 minutes later. I can't figure it out. Does anyone have any ideas why the compressor would wait to turn on, if the pressure checks out fine?
Thanks, Geoff |
Re: A/C Compressor sometimes does not turn on
I'd try pulling codes from the climate control unit; it's ridiculously easy. See the attached (toward the end).
Looks like it's reading a Code 15 - Refrigerant temp sensor open
Is this something I can take care of, or should I take it to the Subie dealership? |
http://serial.cc/pdfs/AC___HEATER____AUOTMATIC.pdf
See page 22 for the location of that sensor. Probably not the easiest thing to get to, but you could get lucky and it just be a loose plug or something.
So I have to remove the glove box, and it's somewhere down there? My guess is that the system would need to be evac'd beforehand?
I'm not exactly sure how to change that sensor out. I'd first get a replacement sensor and then evac the system, then take apart as much of the dash/glovebox area and swap it out. Test it before putting it back together.
Keith |
Keith - Have you done the sensor replacement before? I'm just trying to figure out its complexity. I haven't even seen the evaporator core yet.
I would first make sure that the system is properly charged. I have been told that when they are not properly pressurized it will cause compressor to act sketchy.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
It's just that the compressor won't run sometimes...and the HVAC is giving me code 15. |
$5 says there's a loose plug that's preventing it from working.
Thread Tools | |
Display Modes | |
