Old 04-27-2011, 08:24 AM
Geoff's Avatar
Geoff Geoff is offline
Send a message via ICQ to Geoff Send a message via Yahoo to Geoff
Jerky throttle :(
My '92 seems to have an issue with the throttle being either unresponsive or jerky, especially when cold.
All brand new:
NGK Spark Plugs
TPS Sensor properly calibrated using Select Monitor at the dealership
2 new O2 sensors
Air Filter
Fuel Filter
Have tried:
2 Different MAF sensors, same results
Basically, I keep my foot at the same place on the throttle, and after a moment, the car jumps up and goes. If I give it more throttle than about 20-30%, it doesn't do this, but it does get annoying. It's almost like there's some sort of lag going on.
Any ideas?
Old 04-27-2011, 09:31 AM
Re: Jerky throttle :(
Maybe the TPS is just bad?
Old 04-27-2011, 12:27 PM
Geoff's Avatar
Nope - Have tried 2 used and 1 new TPS. The TPS registers correctly.
Old 04-27-2011, 01:39 PM
Cam Cam is offline
You can test your crank/cam sensor. Alldata says to test for a wave signal using a magnet. In other words, take a volt meter and connect pos to one of the prongs and neg to the other. Wave a magnet in front of the sensor and see if it registers a change. I don't know what the values should be exactly, but if they are all three the same ballpark, I doubt that they are bad.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 04-27-2011, 06:21 PM
michael's Avatar
michael michael is offline
What Potholes ???
Have you checked for codes?
Wanted: Steering Wheel
Old 04-27-2011, 06:57 PM
Geoff's Avatar
There are no codes. Engine idles a little rough in Park as well.
Old 04-27-2011, 07:57 PM
Check the coolant temp sensor if you haven't. Only about $25 for a new one. Often times won't throw codes when they're going bad, ESPECIALLY on 92's.
Old 04-27-2011, 08:05 PM
Cam Cam is offline
You can check the cts with an ohm-meter. It should read 2k-3k ohms when at room temp. Roughly 60 degrees. When warm (about 170 degrees) it should drop to 400-600 ohms.
Cam
'92 Ls-L Dark Teal
Old 04-27-2011, 11:32 PM
Geoff's Avatar
Where's the Coolant Temperature Sensor located? Any pics? I've got a multimeter I can check it out with.
Old 04-28-2011, 01:04 AM
It's on the coolant crossover pipe, on the driver side of the engine. Take off the H6 engine cover and there are 2 sensors just below the intake manifold. The one with 2 wires and larger connector is the one to check.
Old 04-29-2011, 06:03 PM
Geoff's Avatar
Just replaced the sensor - It was only $22 shipped, and I'm sure it's never been changed. Since the drivability issue was intermittent, will have to see if the new sensor helps...will post if it does.
Old 04-30-2011, 05:55 PM
Geoff's Avatar
Nope, new coolant temp sensor didn't fix it. It's usually from a start or low speeds...nothing, nothing, then SURGE of power. Should I look into doing the crush mod? Any other ideas?
Old 04-30-2011, 06:49 PM
Geoff's Avatar
Tried in manual as well....the throttle hesitation is still there in first from a stop. Any ideas?
Old 05-02-2011, 11:37 AM
Geoff's Avatar
Just ordered a NEW MAF. Both of the MAFs I'm using are original. Even though I've cleaned them and received similar results, won't hurt to try, since I've replaced both O2s, all of the injectors with rebuilt ones, the TPS (adjusted as well) and plugs. Running out of things to change now. :P
Engine seems to idle smoothly while in gear, not in park or neutral, and throttle response is still uneven, SOMETIMES. :P
Old 05-02-2011, 06:06 PM
michael's Avatar
What Potholes ???
I. Wish I could remember but I had the same symptoms that a sensor fixed. I thought it was either a knock or o2. If you did the o2 already you may want to test your knock sensors.
