Old 04-25-2011, 08:06 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Idle speed observation
Ever since I cleaned my throttlebody and replaced my IACV, pcv, I have noticed a higher idle.....
Normally when the car is at running temp I am observing 1000-1100 rpm...when I go to park and put the transmission in "P" the idle jumps to 1500 rpm and stays there.
I know I didn't loosen the cable nuts and adjust the slack on the throttle cables or touch the TPS at all other than to unplug it, but what has caused this?
What is a good solution for this as well?
1995 Subaru Svx L / AWD
Old 04-26-2011, 12:51 PM
Re: Idle speed observation
sounds like a vacuum leak, spray carb cleaner around where you were working to see if the idle jumps at all. could also need to reset the computer to relearn the iac valve position.
Old 04-26-2011, 05:16 PM
msvx95's Avatar
It's just a phase
I don't suspect a vacuum leak because I had that tested before I worked on the car when I experienced the symptoms. The mechanic sprayed to check and he said it was ok, but I guess I may have to do that again.
Other than disconnecting the battery and waiting overnight, how do you reset the computer?
Old 04-27-2011, 07:41 PM
The hard reset as you described is the best way. You can help discharge any charge in the system by disconnecting the battery and holding the pos and neg terminals together to complete the circuit and drain out any remaining juice. That could work and is the actual procedure on some cars (non subaru's)
Old 04-27-2011, 08:56 PM
msvx95's Avatar
It's just a phase
I've discharged the system before by disconnecting the neg. battery, then turning the ignition to "on" and then turning the headlights on...that usually gets the residual out.
That being said, I had the battery disconnected when I took apart the TB and replaced the IACV so the computer was reset originally.
Old 04-27-2011, 09:01 PM
Yeah, besides that, there is a "soft reset" by using the 2 blue wires and the diagnostic plug, but I found that it did not actually clear the codes in my laguna when I needed to check them. Wound up disconnecting it overnight.
Old 04-28-2011, 05:05 AM
msvx95's Avatar
It's just a phase
Yes I know about this, but my soft reset never worked from day 1....I always have to disconnect the battery and let it sit overnight.
