Old 04-24-2011, 08:11 PM
Cam Cam is offline
Fuel pump resistor
So my car decided not to start on me again today, after resetting my timing belt and installing a new tensioner. I could not hear the fuel pump kick on, so I started digging around. I got 10v at the pump, which seemed understandable since the wiring is almost as old as I am. I decided I would see if unplugging the resistor would help. So I unplugged it and BAM, car started without a problem.
I know I should probably not run the pump without the resistor, but a guys got to do what a guys got to do to get to work. However, the only thing it says on it is A15-000R20, and I cannot find the part number anywhere.
I also plan on replacing the pump just in case soon, and will probably go with the wahlbro (I probably butchered that spelling).
Thanks in advance for the help, guys.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 04-25-2011, 01:18 PM
Cam Cam is offline
Re: Fuel pump resistor
Turns out the pump was the problem. I have one on order. It must have just been getting weak, so unplugging the resistor allowed it to work for a few minutes longer.
Cam
'92 Ls-L Dark Teal
Old 04-25-2011, 02:27 PM
Cool, does this mean you've got all your issues sorted and ready for some dyno time??
Old 04-25-2011, 02:29 PM
Cam Cam is offline
Not sure yet...hopefully. I still need to do the ring gear in the rear diff to match up my ratios. But trust me, I'm working on it.
Cam
'92 Ls-L Dark Teal
Old 04-26-2011, 10:34 PM
Cam Cam is offline
So I did my fuel pump today...it was not all that bad once I got that clip off. I used an american made pump replacement since that is what my buddys shop was able to get through worldpac. I am pleased so far. Installation was simple, it fit correctly, and it seems that even though the filter is clocked slightly differently my floater still works properly.
EVEN BETTER NEWS, I am not "counting my chickens yet", but the idle seems to have improved. It has gone from rough and bouncy to slightly rough, like its got some lobe in the cams . I will see if it will improve with a little tweaking here and there (by that I mean the throttle body), then I can get around to restoring the rest of the car.
I will keep everyone posted on the running condition of the car since so many of these threads die without an answer.
Thanks to OT who I talked to on the phone today, as well as a couple other people (Nikfu had a helpful pic of the clip in an older thread) who contributed useful info.
I think I am still light headed from the gas
Cam
'92 Ls-L Dark Teal
