Old 04-24-2011, 05:25 PM
Cam Cam is offline
crank/cam sensor question
Anyone know if we can use 2001 outback or 1998 forester sensors?
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 04-25-2011, 02:30 PM
alia176 alia176 is offline
Re: crank/cam sensor question
This is probably a dumb reply but would subaruparts.com provide the p/ns for each of the vehicles you mentioned? If the p/ns are the same, then My guess is that they're compatible!
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 04-26-2011, 01:09 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
The SVX knock sensor, part #22060AA031, is also used on the 1990-'96 Legacy, 1995-'96 Outback and 1993-'96 Imprezza according to subarupartsforyou.com
No crank or cam sensors listed for the SVX.
Gene
Gene and Ben
Old 04-27-2011, 07:39 PM
Cam/crank sensors can be used off most year legacy/outback/impreza/etc(pre 99, but you have to modify the connector. It's a simple magnetic signal and the sensors are the same size from the ones I have looked at and just a 2 wire. The second crank sensor on the SVX is unique to the SVX only if I remember correctly.(1 crank sensor is literally the same sensor as the cam sensor)
