Old 04-17-2011, 01:11 PM
radarwhiz's Avatar
Fairmont State University
Brake bleading question
Originally Posted by SoCal LS-L View Post
you will have a lot of bleeding to do.... start with the master cylinder, then bleed the caliper the farthest from the master cylinder (pass. rear), then driver rear, then pass. front, then driver front.
...as was always my understanding of the procedure. But then I found this in the Chilton repair manual:
I presume this is because of having ABS but does it really make that much difference in what order to bleed?
Any insight on this?
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 04-17-2011, 02:20 PM
Re: Brake bleading question
It does make a difference. Usually it's furthest to closest. I'm not sure why Chilton gives that pattern.
Old 04-17-2011, 02:47 PM
radarwhiz's Avatar
That's what I thought.
Elazar
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 04-18-2011, 11:28 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Based on the diagram, secondary first then primary last. I believe it is the same as furthest to closest.
Old 04-18-2011, 07:57 PM
Bobb Bobb is offline
Hi everyone, Subaru uses two[2] complete and separate system, while most other cars switch to a both front and one rear brake system when the brakes have a problem. I don't know how this would affect bleeding the SVX brakes, but it probably has something to do with it. My Subaru guy says you can use the anti lock brake system to bleed the system. Take care, BOBB
