Old 04-04-2011, 06:29 PM
zaueugen's Avatar
zaueugen zaueugen is offline
different color gauges using stage gel
those who have done the gauge mod using stage gel, how did u remove the needles off the gauge face without breaking it? there are 2 screws that i unscrewed but its still clinging in the needles. thanks
Old 04-04-2011, 07:06 PM
dragoontwo dragoontwo is offline
Re: different color gauges using stage gel
gently pry evenly from underneath them.
'92 SVX LS Pearl White - 6mt
Old 04-04-2011, 08:18 PM
zaueugen's Avatar
here is a picture of the temp gauge, the middle circle thing that holds the need is the piece i cant figure how to detach from the rest, so that the plastic piece with illustration on it comes off. I unscrewed those two screws and tried to gently pry of the needle part, but it wont come off.
Old 04-04-2011, 08:26 PM
It will come. Just make sure you have even pressure on both sides under the round portion that holds the needle.
Old 04-04-2011, 08:47 PM
zaueugen's Avatar
ok i will try it tomoro, will the needles still acuurately work when everything is put back?
Old 04-04-2011, 09:10 PM
radarwhiz's Avatar
Fairmont State University
It's easiest if the gauge cluster is still in the car. Before you pull the needles off, start the car and allow to warm up to normal operating temp. Then with engine at idle mark the positions of the needles. When installing the needles, just have the engine idling and at operating temp again and line align them with your marks.
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 04-04-2011, 09:48 PM
ridered777's Avatar
Finally HAS a 3rd pedal!!
I have a "tool" that I use for this, when I made a one-off custom gauge set for my Duster
I'm sure you can buy one, or as I did, make one. Take a standard (slight shorter with a FAT tip) flat-head screw-driver. Then put a 90deg bend in it a few inches from the end. Repeat for another.
Now you have 2 "prying" tools to help it come off. Not ideal, but it gets the job done.
-Craig
Old 04-04-2011, 10:33 PM
zaueugen's Avatar
thanks ridered i will try that, hope fully without scratching the surface of the black paper... i wonder if the gauges will work properly once i put them all back on hope so..
Old 04-04-2011, 10:45 PM
radarwhiz's Avatar
A small fork always worked fine for me.
Elazar
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 04-05-2011, 07:20 AM
zaueugen's Avatar
got em off!! i used a smal pair of nail scissors.
