Old 04-02-2011, 01:33 PM
Cam Cam is offline
Throttle Body set screw
Mine just broke...
Hope it doesn't matter!
Mike mentioned that he has had to close his butterfly valves a bit to make it idle better, but I don't remember if he said he closed them all the way.
Anyways, I am ordering a replacement screw, and hoping it runs till then.
It always something
I'm thinking that because the cams have more duration, they take in enough air with the flow through the IACV, and so closing the butterflies at idle will help adjust the air intake back to a normal amount.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
