Old 08-31-2002, 09:22 AM
Ca$h
Whats the story with recalling 92s?
Is it true I can get more filters on my transmission if they aren't there? ANd that Subaru will pay for it? Or does it have to be under warranty?
- Ca$h
Old 08-31-2002, 09:46 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Filters
Yes the 92 did have a retrofitted external filter. If you have it it should be right behind the radiator area where the atf hoses go in. Take your plastic bottom cover of and take a good look. If its not there call the Subaru 1-800 number or send them an email. Explain that you just bought the car give them the vin and tell them you just wanted to register it with them (in case of any later recalls) and would like to find out if there are any recalls that haven't been done to the car. If they say no then tell them that you heard that the 92 was retrofitted with a filter and that yours doesn't have it. They may let you get one but from what I remember other posts was that it wasn't a mandatory recall but rather a goodwill recall. That was also 8 years ago at least so I wouldn't think they would have to honor it.
If they don't want to honor it go get yourself an aftermarket set-up. Its cheaper and the filter (which is just a fram model number is cheaper too). try www.summitracing.com. They're real good at getting you the stuff you need and helpful on the install. I got my cooler and digital tranny temp gauge through them.
Old 08-31-2002, 10:29 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
The filter (which includes hoses and hardware) is available from the dealer or subaruparts.com for around ten bucks. It was part of a TSB and would have to be under warranty to get it fitted for free.
Randy Johnson
Mike Davis -- at Reading VI
Old 08-31-2002, 06:40 PM
LarryIII LarryIII is offline
Cash,
There was a special TSB to add an external ATF filter on 92's & 93's. I think it expired about 1 1/2 to 2 years ago. Your local subie dealer may honor it for free. If not, I suggest that you get an aftermarket ATF filter. I think one model has a connection for a temp. gage. Good Luck.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 09-05-2002, 08:48 PM
SVX_MY_BABY's Avatar
If the filter recall wasn't done, you may want to check that the fuel filler/cap recall and the Wireing recall were also done.
There was a vacume problem with the filler. The wireing recall rerouted power through different fuses . Sometimes you'd have power drops when signal lights and/or wipers were used with a/c & headlights on if I remember correctly. Then there was the front strut warranty replacement deal to 'quiet' the thumping in the front end cased in conjuction with the floating calipers. (It did quiet but to the detriment of handleing in my opinion.)
Old 09-05-2002, 09:35 PM
I'm not familiar with this wiring recall. Do you have any more info on this? A quick search didn't return any info.
Come to think about it...what's this about the fuel filler recall?
Old 09-06-2002, 05:11 AM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
The wiring recall rerouted power through different fuses . Sometimes you'd have power drops when signal lights and/or wipers were used with a/c & headlights on if I remember correctly.
I also would be interested in more info on this recall,my car seems to suffer from this condition.
Old 09-06-2002, 05:56 PM
I never heard about a wiring or a gas cap recall.
Please elaborate.
The only TSBs I know of for 92's & 93's are for the struts, ATF filter, and dashboard creaking.
Old 09-06-2002, 06:27 PM
What happened with the struts???
I'm missing a lot of information
Old 09-06-2002, 09:01 PM
mattski mattski is offline
My 97 dashboard still creaks like stones are hitting the windshield. Is it too late or worthwile to get that fixed?
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 09-06-2002, 10:43 PM
nordique14's Avatar
Who watches the watchmen?
checkout TSB summaries
TSB summaries can be found at Edmunds.com
http://www.edmunds.com/products/maintguide/index.html
They don't list details, but the summaries should help a little. I just found a TSB that applies to my other car. Now I just need to convince the dealer to fix it for free. If anyone knows where to find full text TSBs for free, please let me know.
Old 09-07-2002, 09:34 AM
Here is the TSB
http://members.tripod.com/quick_svx/.../42747818.html
Old 09-07-2002, 09:42 AM
Here's the TSB for the 92's. I would have thought that the problem was fixed on the 97's.
http://members.tripod.com/quick_svx/.../42748897.html
Old 09-07-2002, 10:30 AM
I pulled my old repair records but can't find any specific ref. All I found was a warranty repair in Aug of 93 where the gas cap was replaced. I had not asked for this and distinctly remember that Subaru had the dealer do the replacement due to some sort of seal problem which caused a vacume in the fuel system that affected fuel flow (or lack of)
Same for the rewire. Oct 93. Took my car in for regular service and found it wasn't ready when I went to pick it up. The mechanic was lying on the driver's side floor soldering wires to reroute electrics. I still have the mark in my floor mat where he dropped the soldering iron.
Next time I'm at the dealer I'll ask if they still have the info from Subaru.
