Old 03-27-2011, 09:22 PM
NO CEL w/ key on and no spark?
Just looking for additional opinions.
The Claret was out on its shakedown run with the new engine in, and all of a sudden shut off, and cranks, pumps fuel, but will not start.
When I turn the key to "on" the CEL is NOT illuminated as it should be.
-I checked the loop connector at the right rear of the intake manifold and it has a clean mating surface and the wire is attached firmly.
I am going to swap in a different ECU to check, but due to the fact that the car is about two hours away from home right now, I was looking to see what other's suggestions are, as it is difficult for me to go back and forth checking one item at a time.
Old 03-27-2011, 10:02 PM
Re: NO CEL w/ key on and no spark?
I guess you checked the timing belt?
Old 03-27-2011, 10:12 PM
cranks fine (doesnt sound like belt jumped) sounds like its in time ok. ill pull the covers when i see the car on Tuesday or Wednesday. I installed the belt, new idlers etc on the motor before putting it in and cams and all were aligned 100% and the car was running well when it suddenly cut off.
Old 03-27-2011, 10:26 PM
Originally Posted by Hocrest View Post
I guess you checked the timing belt and the TPS plug?
Dave, the weird part is that when he turns the key to on, the CEL does not come on at all?!
And this is just after driving the car...
Wiskey Tango...
What, when disconnected/ungrounded/unpowered, shorted, causes the CEL not to light?
Old 03-28-2011, 05:31 AM
You discovered Melis's TPS came unplugged that one time that her's wouldn't start.
Old 03-28-2011, 08:42 PM
ECU and Ignitor tested in another car and came through ok. I will try checking and then swapping the wiring on the intake manifold.
Old 03-28-2011, 09:59 PM
As far as things causing the CEL not to light I have;
1) The CEL light is burned out. Not very likely.
2) The connectors at the ECU are not COMPLETELY plugged in.
3) Under the hood, probably where he changed engines
are four main electrical junctions, on the passenger side,
above the bell housing.
The top square one closer to the passenger fender will allow the engine
to crank without starting, and not allow the CEL to come on.
Not starting is one thing, the missing CEL is another.
If you do have to spend some time under your dashboard at least you will have more room than some of us.
Are you going to finish that?
Old 03-29-2011, 06:50 AM
My aim is to get it all figured out/buttoned up today/tonight after work. I will post my results afterward.
Old 03-29-2011, 05:50 PM
Checked plug at rear of engine. Changed engine harness on intake and cleaned/greased ALL connections. Still stumped.
Old 03-30-2011, 04:26 AM
Did you end your eBay listing till you could get it worked out or did it sell?
Old 03-30-2011, 04:55 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Can you figure out anything more thru the service manual?
PS: the car is having emotion, doesn't want to leave him.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 03-30-2011, 06:19 AM
Well, I can't really sell a broken car under the guise that it starts, especially when I was getting calls from Canada and all over the country asking if I could pick them up at an airport...
I am going to look over a wiring diagram and pick up a multimeter and test light. I guess I'm cancelling any other plans I had this weekend.
Old 03-30-2011, 06:22 AM
Cam Cam is offline
This might sound kind of stupid, bit did you check all your fuses and relays?
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 03-30-2011, 06:23 AM
Pulled all fuses, and everything looked ok.
Old 03-30-2011, 09:38 AM
I've seen fuses that look good, but are blown. Check them all with a meter.
Do you have another ECU you can swap?
