Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Engine Management
Old 03-14-2011, 04:55 PM
Banned
Hydra EMS Nemesis II ver. 2.7 RELEASED
Ok so as promised here is the breakdown of the new Ver. 2.7 of Hydra EMS Software and Hardware. As far as when I will start selling them, I'm going to get one in here probably in the next month and start to play around with it and see how it differs from 2.6 so that I can better support those of you who decide to purchase. Also we should still be able to trade in any 2.6 EMS for a Stage III 2.7 Working on IRIS support and VE Maps, VE Base Map will be the only base map that will cost.
Pricing:
Hydra Nemesis: Pricing broken down by stage, see below
Base Maps: $0 (currently offering for free with purchase, 2 maps, one from Element, and Tom's original 2.6 map converted to 2.7)
Torque Control harness upgrade and Map: $50 (not currently offered)
Wideband Sensor and Harness: NTK L2H2 kit for $450 extra, and their standard kit for $260
AIT(Air Intake Temp) Sensor and Harness:~$99.95(in development)
Hydra 2.7 Specs and breakdown
The Hydra2.7 has complete new firmware and software along with new processor with onboard datalogging and new idle, boost control, aux map and long term trim strategies. The 2.7 will also have capability to configure for additional sensors as inputs with configurability. Stage5 Epsilon has built in CAN Bus for use with external dashes, so you can run a dash and tune at same time. Hydra2.7 will be firmware upgradeable remotely without sending the ecu back. Each stage will be upgradeable to the next remotely without sending the ecu back.
You can also just buy individual Capabilities if you do not want the next full stage upgrade.
Stage 1 Alpha and Stage 2 Beta will be stripped down versions with fewer outputs and inputs then the current Hydra2.5 and 2.6. To get equivalent Outputs as the Hydra2.6, you will at least need the Stage 3 Gamma upgrade
Alpha Stage 1(would need to be upgraded slightly to work with the SVX) $1350(OBD1) $1450(OBDII)
• 4 injector
• 2 inputs,( 1 analogue and 1 digital)
• 6 outputs
• Knock control
• Internal Datalogging Fixed 8 channels
Beta Stage 2 $1500(OBDI) $1600(OBDII)
• 6 injector
• 6 inputs(4 analogue, 2 digital)
• 9 outputs
• Aux Fuel/Ignition Map
• Launch Control
• Intake VCT Control
• lambda Target
• Tip-in Enrichment
• injector phasing
• Basic boost Control
• Staged Injection
• Internal Wideband Logging
Gamma Stage 3 (equivalent to ver 2.6) $1700(OBDI) $1800(OBDII)
• 8 Injectors
• 10 inputs (4 analogue, 6 digital)
• 14 outputs
• Knock control
• Launch Control
• lambda Target
• Tip-in Enrichment
• injector phasing
• Staged Injection
• Antilag Fuel /Ignition Map
• Exhaust VCT
• Immobilizer request
• Valet Request
• Flat Shift
• Alternator Control
• VE Mode
• Alpha N Mode
• Boost Compensation
• Gear Correction
• Individual Fuel and Ignition Trim
• STT Ignition Trim
• Throttle derivative
• 3D maps
• Manifold Pressure delta trim
• Internal Datalogging Configurable 8 channels
Delta Stage 4 $1800 (OBDI) $1900 (OBDII)
• 8 Injectors
• 10 inputs (4 Analogue, 6 Digital)
• 14 outputs
• Knock control
• Launch Control
• lambda Target
• Tip-in Enrichment
• injector phasing
• Staged Injection
• Exhaust VCT
• Valet Request
• Flat Shift
• VE Mode
• Alpha N Mode
• Gear Correction
• STT Ignition Trim
• 3D maps
• Steering Load
• Traction Control
• Coolant Temp RPM Trim
• External Map sensor
• Engine Speed Delta Trim
• Idle speed Error Trim
• Calibration Input Maps
• Fuel Pressure correction
• TPS Position Trim
• Barometric Compensation
• Fuel Temperature Compensation
Epsilon Stage 5 $2000(OBDI) $2100(OBDII)
• 8 Injectors
• 14 outputs
• Knock control
• Launch Control
• lambda Target
• Tip-in Enrichment
• injector phasing
• Staged Injection
• Exhaust VCT
• Valet Request
• Flat Shift
• VE Mode
• Alpha N Mode
• Gear Correction
• STT Ignition Trim
• 3D maps
• Steering Load
• Traction Control
• TPS Position Trim
• On Board CANBUS Control( for CAN expansion Box and Dash Support)
• Two Internal feedback outputs
• Humidity Correction
• EGT Correction(requires CAN Expansion Box)
• Flex Fuel Support
• External Wideband Support
• Vehicle Speed Pit Limiter
Optional Capabilities
• Sensor Calibration maps
• Advanced Output Configurations
Old 03-14-2011, 06:04 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: Hydra EMS Nemesis II ver. 2.7 RELEASED
Geezus!!!!!
I'm glad this option isn't dead.
Old 03-14-2011, 09:38 PM
Banned
definitely far from dead and more maps soon to come for those who have modified their SVX with bolt ons such as intake, exhaust, headers etc
Old 06-24-2011, 03:35 PM
Banned
bump... anyone want the best engine management out there??
Old 07-17-2011, 10:42 PM
sikend667 sikend667 is offline
Steve
where do i get one of these
Old 08-03-2011, 01:38 PM
Banned
Give me a call we can order one in for you (801)948-0877
Old 01-22-2014, 08:00 PM
Banned
New maps available and new harness has been updated to include IRIS functionality directly out of the box. VE Stage II and Stage III maps will be getting designed in the next few months.
Old 01-27-2014, 02:26 PM
Until this guy makes good on the intakes, it would not be wise to give him any money.
Old 01-27-2014, 02:31 PM
Tireiron Tireiron is offline
It is not listed on their site, but Phil Grabow at Element Tuning is also able to get the hydra for the SVX. He will be tuning mine this spring so I can dial in the supercharger perfectly.
Old 02-01-2014, 05:11 AM
Yes, Phil at Element tuning is the man to go to for Hydra products. Not only is he a stand up guy but he is also very knowledgeable. Please seek him out if you are interested in the Hydra Nemesis for your SVX
Old 02-01-2014, 09:11 AM
wdb wdb is offline
dances with roads
Another vote here for Phil Grabow. I never used him personally but he has a great reputation among STi folks.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
