Old 08-27-2002, 09:48 AM
Question Turn signal lever
Has anyone ever removed or replaced the turn signal lever. My button that brightens the clock and temp etc. does not work. I don't know if this is a major job, and I should just leave it that way, or try to replace the whole lever. Any thoughts on how to fix just the button switch would be appreciated as well. Thanks
Old 09-02-2002, 10:19 AM
Bump
Old 09-02-2002, 10:43 AM
lee lee is offline
I looked at an Alldata CD I have and the procedure to replace the whole signal mechanism is incredibly complicated. I can print/scan and post if you want, but let me give you a hint ... remove airbag, take off front wheels, undo steering shaft yoke, pull steering shaft, pull steering wheel, etc.
Maybe somebody knows a better way to just do part of the job.
Old 09-02-2002, 06:11 PM
Lee
I just got out of the SVX, and it isn't that hard to see those numbers afterall. Thanks, I thought that it might be that easy. I have many more things to be fixed before I will ever get around to that. All I have to do is drive when it is dark, and it will be just right.
Old 09-03-2002, 08:58 AM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
The turn lever is part of the Combination Switch Assembly.
New combi switch = $$$$$. Find a used one.
I recently replaced mine because the one of the contacts for the wires that activate the airbag became faulty. It's not too hard, but you will need a security torx bit (a torx with a hole in the centre).
It took me about 2 hours, and I found one of the bolts that hold the plate directly underneath the steering column stuck. I ended up unscrewing the ignition and wiggle the wire thru a very tight gap around the ignition. Other than that, it wasn't too bad, although you will be working upside down underneath the steering column for most of the time.
I have my old combi switch laying around somewhere. I was going to take it apart to see how it worked at some point, but if you can scavenge it, we can talk.
VK
