Old 08-27-2002, 06:58 AM
Ca$h
Tips on Changing ATX fluid
Alright, after class today I'll run and buy some ATX fluid, mobil one synthetic. How much do I need? Also, do I need a filter? Where do I get one? Dealership? Or what?
- Ca$h
Old 08-27-2002, 08:42 AM
Mr. Pockets's Avatar
Moderator
Re: Tips on Changing ATX fluid
- Ca$h
The problem with just changing the fluid is that you only get about half out. The tranny only has like 20k on it, right? I'd have it flushed - BUT NOT BACKFLUSHED!!! My dealer did it for less than $200.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 08-27-2002, 12:16 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
ATF
Should be around 5 quarts. Check out your manual. It'll tell you how much. If you don't have one call subaru. They'll send you out one free if they have a copy. My SVX took nearly 7 last time I did it but I'm guessing I'm getting some draining out of my tranny cooler. No filter needed unless you want to replace your external filter. Kinda pricy $60ish for me at my dealer. Others have gotten it cheaper by saying they need the whole kit (92's didn't have it originally). If I was you I'd first check your old external filter out to see the condition on the outside. If it wasn't replaced when the tranny was rebuilt definately get a new one. It should be behind the radiator.
Old 08-27-2002, 02:51 PM
gcookaustin
I have changed my tranny fluid at least three times. The first time I filled it up with motor oil because I am a retard (hence my 'custom title'). The second and third time I replaced what I could with real tranny fluid, and replaced the filter and pan gasket. Gasket and filter were twenty or thirty dollars each on the internet.
Old 08-27-2002, 04:36 PM
dromano's Avatar
dromano dromano is offline
Re: ATF
The Subaru add on filter is under the battery. If you had the dealer flush the tranny that should have involved at least 10 quarts. 10 quarts is the capacity.
David
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
