Old 12-21-2010, 08:50 PM
Huskymaniac's Avatar
Uses the ignore feature
Re: Passenger side oil leak
Originally Posted by immortal_suby View Post
4 hours for only the passenger side and pcv? yikes.
I think 4 hours was for both valve covers and the PCV.
Tony
Old 12-21-2010, 10:36 PM
Originally Posted by Cam View Post
Just looked it up. $249.97
Part # 10105AA060
Where did you find it for that price?
Tony
Old 12-22-2010, 12:10 AM
Cam Cam is offline
Subaruparts.com. see if your local dealer will match the price thoigh. Ordering from the website is expensive with shipping
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 12-22-2010, 01:07 AM
It comes to almost $250 on the dot after shipping costs from 1stsubaruparts.com FYI. There prices are better in most cases, just don't have the nice parts diagrams...
Old 12-22-2010, 07:56 AM
Thanks. Unfortunately, they have already ordered the parts. I did make sure to tell them to get the washers too.
Tony
Old 12-22-2010, 11:21 AM
kwren's Avatar
kwren kwren is offline
Might be a good time to get that head gaskets thing done as well. Would be just about like a new engine!
Keith
Old 12-22-2010, 11:16 PM
I would say this is good advice. The reseal kit does include washers, and valve stem seals (part of valve train). Also included is the O-ring for the dipstick. All other seals on engine are included as well (Headgaskets, O-rings internal and external for the block, and too much other stuff to list). It is the best deal as I believe its about 300 bucks but I cant really remember at the moment. It's around there somewhere, but considering the head gaskets are half of that by themselves, and the valve covers are not cheap themselves, you save a lot of money in the long run by getting the reseal kit. It should literally have every seal for the entire engine.
Part # 10105AA060
OK, when he is done with the valve cover gaskets and PCV, is there anything else he should replace or clean in connection with the stuck/clogged PCV? For example, are there hoses or parts that might be filled/coated with oil that should be cleaned? That is, other than the obvious coating of oil on the suspension and block and the pool of oil on top of the plastic cover.
I have noticed that my long term fuel trim number is still high on that bank even though it has been more than 2 months since we replaced the O2 sensor. Maybe it was related to this valve cover leak and/or PCV issue?
Tony
Old 12-22-2010, 11:46 PM
Cam Cam is offline
As far as cleaning, you should not have to clean any hoses or anything. The valve is threaded directly into the intake manifold.
The fuel trim I doubt would be related to an oil leak, but I am not sure. Doesn't seem logical to me, though. What brand O2 sensor did you use?
Cam
'92 Ls-L Dark Teal
Old 12-23-2010, 07:46 AM
I used a Bosch O2 sensor but the fuel trim was high before the O2 sensor was replaced. It just hasn't come down after the new sensor was installed and it has been quite a while.
On the hoses, he did find some oil in the hoses when he checked for vacuum to test the operation of the PCV. I have no idea which hoses or where else oil might have sneaked into that should be cleaned.
Tony
Old 12-30-2010, 08:05 AM
Well this is turning out to be more involved than I had hoped. They STILL have my car. First, they didn't order all of the gaskets. They didn't realize that the three gaskets on each side were sold separately and the dealership that sold them the parts didn't know either or didn't tell them so they only got the larger gasket for each side. By the time the other gaskets showed up the next day, they already had other cars in the bays for other lengthy work like timing belt changes so they didn't have enough time to get my car done. We are on day three now. Luckily, I am on vacation so it isn't too much of a hassle.
What technique have people used to gain access to the driver's side (left, now that I know) valve covers to get them on and off?
Tony
Old 12-30-2010, 01:09 PM
kwren's Avatar
Not sure but I think it is mostly 10mm.
Keith
Old 12-30-2010, 01:41 PM
Cam Cam is offline
You must remove the battery, and i think a couple brackets . Its been a while since I looked at a complete engine bay. I am curious why you ask? If a shop is doing the work, and they can't figure out how to do the valve covers, maybe you should no longer be their customer. I believe the book says to pull the engine to do valve covers. It's not necessary, but for a well equipped/experienced shop it is probably quicker that way.
Cam
'92 Ls-L Dark Teal
Old 12-30-2010, 02:15 PM
I know he removed the battery but he had to "jack up the engine" a little to get all of the bolts out. He didn't have to remove the entire engine though. One thing I did notice when I got home was that he didn't snap the spark plug wire clips back into the covers. I know the plastic is old and brittle so maybe he just figured they would break and not stay in anyways or maybe he tried but they broke on him. The engine was hot so I didn't attempt to snap them back in myself yet. On the plus side, they charged less than $200 in labor to do both covers and the PCV.
Tony
