Old 12-05-2010, 09:17 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
exhaust leak?
i think i have a slight leak. it sounds like it's under my door. it makes a slight sound when i'm parked and let the gas off after i rev it a little. (did this since i bought it) it sounds like a sound i would make with my nose. like breathing out of it intensely while humming. if you have this problem you know what i'm talking about. haha, and also since a few days ago it has been a little bit louder than usual. and i hear it next to me. maybe it's because it's starting to get down to 15 degrees at night? not sure. also, on a super cold morning after just starting her, my exhaust tips were putting out smoke (like any car does in 10 degrees) but it also came out the side of my car a little bit. so i think there is a small problem. i need to take her to a shop some time soon. my gas milage has gone down from 20-21 to 18-18.5. i hope it won't be too expensive.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 12-05-2010, 09:27 PM
Green1995SVX's Avatar
Re: exhaust leak?
Your gas mileage will always go down in the winter. I believe it has something to do with fuel formulation.
Your leak is likely worse because of the colder temps. It's probably the gaskets between the converters or the flanges have rusted off or are starting to rust off. Both are easy/cheap fixes.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 12-05-2010, 10:29 PM
B 4 You's Avatar
#lolsvx
Re: exhaust leak?
i hope so! i can't fork much money into this car right now. i need new strut mounts and cv joints.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
