Crank pulley wore through belt cover?
So after lots of swearing, I finally have my motor out of the car to replace my bad head gasket. When tearing into it, I found that my crank pulley has worn through the timing cover plastic! I know this can be caused by a stock pulley separating and wobbling, but this car has been running a one piece Perrin aluminum pulley since last summer, and it certainly wasn't like this when I installed it! Anyone know what might cause this, or how I can fix it? I was thinking about putting a couple washers directly behind the pulley to space it out enough where it won't rub when I reassemble it.
Also, does anyone have a center timing cover for sale?
Ebony/Gray '92 LS-L, @123k - bought 01/17/2010, parked for 10 years. Getting back on the road. |
This happened to me when I installed an aftermarket pulley. The problem was solved when I had a stock pulley installed.
Check the pulley key slot for wear.
Re: Crank pulley wore through belt cover?
Don't use washers to move the pulley. It will move it out of alignment with the other pulleys that it drives.
The plastic cover warps and the the piece behind it does too.
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
Mine is just like this one.... Like SomethingElse said, it just warps and slowly gets rubbed thru.
Mine is also like this on my red car. It also has wear and holes from when the timing belt exploded 5 years ago. I have been running without any problems since then with the battered cover, its not a "holy crap how do I fix this?" Type of problem. When my water pump went a couple years ago, the timing belt was still in good enough shape for me to reuse.
-Steven 1992 SVX Purple and Black 5 speed swap SOLD *1993 SVX Silver and Black *1994 SVX L Barcelona Red FWD |
Sunvisors that won't stay up, sunroofs that won't go up, bearings that roar, pulleys that cut.
Disclaimer: The above post is on the internet. |
Gosh, way to be a downer!
I have a theory about those rear bearings... has anyone actually seem the bearings upon removal? Did they really fail? Only reason I ask is, I have never heard of one failing completely, I did hear the dreaded roar though, pulled the tire, brake assembly and rotor and the thing seemed really tight and smooth, when I put it back together, I greased the brake caliper slides and the noise went away for months, when it came back, I replaced my warped rear rotors and it has been quiet for 3 years or so...... just saying... also, if you drive upside down, the visors arent a problem either :P
In my H6 Outback the stock rubber/metal pully started to seperate and cut almost through the METAL timing cover. Only made noise on very hot days under load... took a little while to figure out.
Christian- 96 SVX Lsi #821, Bordeaux Pearl, 4.44 98 Legacy Trans, Trans Resistor Mod, Dakota Digital Trans Temp Gauge on A-Pillar Pod (awesome), B&M Trans Cooler in Driver's Wheel Well, External Spin-on Trans Filter, Synthetic Fluids in Trans and Diffs, 17x7.5 Primax 695 Rims, Alcyone Rear Panel, Svxfiles' 5000 k HIDs, Clear Headlights, "BOXER6" License Plate, Hard Wired Radar Detector, 94 Power Up Window Switch, Motor Resealed, new Coil Packs, new NGK Iridium Plugs, PVC Valve, Drilled and Slotted Rotors, Gloss Black Calipers and Rotors, EBC Greenstuff Pads, SS Brake Lines, Superb TomsSVX Cat Back Exhaust... SS Resonator, Flowmaster 80 Muffler, Magnaflow Quad SS Tips, Poly Swaybar Bushings, Endlink Mod, Rear Subframe Bushing Mod. Feels great and sounds even better. Thanks to AWD, LLC. 2003 Outback llb H6 3.0 Titanium Pearl- "BOXERR" Mostly Stock 1995 Bmw 325i Conv. Calypso Red- "RBOXER" Modest Mods 2004 Sea Doo Sportster 4-tec 15' Jet Boat, 1494cc, 1454#, 155 HP= <10#/HP Stock |
Well, hopefully it's just warped plastic and nothing to worry about...at least it seems I'm not the only one, at least. If I replace this plastic part with a new one from Subaru, could I expect the same thing happen to it? I know I could run with it as-is, but I'd rather not. It bothers me like that.
Someone on another forum was saying that it could be either a worn out pulley, worn out crank keyway, or crankwalk. The pulley and crank snout keyway look fine. Has anyone experienced crankwalk in their SVX?
With seven main bearings on a 3-cylinder long block, and 180' piston opposition.... I would assume our engines are pretty immune to it.
I've bought a few of these covers new from Subaru. They come with new gaskets for them as well.
1991 SVX L JDM |
The wear on mine was on that same side, and wore the same way, I wouldnt be worried about any issues with your engine. Just my two cents
My '92 - with a used '92 engine with 115K miles on it - did the same exact thing on the timing belt cover. The pulley was LOOSE - finger tight. Rattled badly when the engine was cold, causing me to think I had a engine bearing that was bad. SVXFILES found the problem and replaced the pulley. While replacing it, he discovered that the "key" and keyway in the pulley were very worn, so be sure to replace the key.
newsvx 1992 SVX LSL, #1215 1997 SVX LSi, #370 "I live with fear every day. Sometimes she lets me go racing." "Getting Older and Slower" Locker: http://www.subaru-svx.net/photos/user.php?newsvx |
Same here... same spot... ugh.
1994 subaru svx le 112k |
Thread Tools | |
Display Modes | |
