Old 10-20-2010, 12:35 PM
SierraSVXer SierraSVXer is offline
first gear only
My 92 with 68 k will not shift out of first gear and there is no slippage of clutches. Is this a low line pressure cause, solenoid "A" or solinoid 1, or vehicle speed sensor ? First and reverse are only operable gears. need input.
Old 10-20-2010, 02:13 PM
XT6Wagon XT6Wagon is offline
Re: first gear only
When my SHO did that it was one of the planetary gears broke.
Old 10-20-2010, 05:42 PM
Re: first gear only
Could be a speed sensor problem, as it won't shift into 2nd if it isn't seeing any speed increase. Any codes?
Old 10-21-2010, 09:35 PM
newkid17's Avatar
newkid17 newkid17 is offline
Send a message via AIM to newkid17 Send a message via Yahoo to newkid17
Re: first gear only
is the car FWD or AWD? does the speedo work? if its FWD it is most likely the speed sensor, but if it is AWD than the rear speed sensor would send the signal for it to shift, (unless the FWD fuse is in) but the speedo will not work.
Old 10-22-2010, 10:08 PM
Re: first gear only
Yes the tach is working. When the engine is started the power light does blink for about 5 seconds . I will try a self trans diagnosis and see what comes up. I do have access to all the shop manuals. Thank-you for input. Steve
Old 10-22-2010, 10:39 PM
major7venth's Avatar
major7venth major7venth is offline
M7
Re: first gear only
Any codes?.. If it is an AWD car, disconnect #2 speedo sensor (at the front dif ) drive it and see if it sets a speedo sensor code, if so, that means the TCU and all is functioning and will not tell you otherwise that the problem is in the trans and rebuilt it must be.
Old 10-23-2010, 02:35 PM
Cam Cam is offline
Re: first gear only
Count the blinks. These are you tcu codes. The fsm should be able to tell you what code it is, or you could do a search here.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
