#31
Re: Transmission Mods
Huskymaniac wrote.
When the TCU cuts the torque for the change, the engine speed slows to the next ratios speed, this prevents the torque converter from working during the change. By preventing the torque cut, the engine will drive the converter into a stall condition, to match the speed difference, and will multiply the torque. This is most noticeable when down shifting to overtake on the highway. Instead of the car lagging there waiting for the change to take place and the power to come back, the change is instant, with the torque increase accelerating the car out and around, spending less time on the wrong side of the road. Harvey.
#32
As for transmission protection, diff fluid is important. Change it. The diff is in a heat-sandwich, engine, transmission, and two drive axles. We bought both Pearls and the Teal with broken front diffs. This last bit, explained by Harvey, less time on the wrong side of the road, is the most important thing to me. Saving lives is even bigger than saving transmissions, especially when its my life . Shift delay was a noticable problem the first week I owned my new 92 SVX, with a brand new car and transmission. I waited for an opening, nailed it, and waited. Showing off my new SVX a bit, I remember the pass, closer than I planned. More recently, as a passenger in the Teal SVX, oldest driving it, he pulled out to pass. The shift delay is significant. It looks like you should have more than enough time for a safe pass, but too much time wasted without real power to the wheels. There was enough, but more than enough is better! Now, no more of this this type of downshift delay with QC installed. You are Quickly Changed into a lower gear before you hit the oncoming lane. My second son calls his QC "insta-shift". He said it feels like 'power mode' to him. He complains about his worse fuel economy. He can't resist testing the shifts and Stebro, every time he drives it
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 Last edited by NeedForSpeed; 09-28-2010 at 05:58 PM. |
#33
Turning the cruise control on will also override the power mode mod. And will lock the TC as normal.
#34
use the cruise paddle to engage/disengage Power mode as necessary for freeway driving.
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
#35
Yeah but I don't like the idea of the TC not locking up, even for around the town driving. It defeats the purpose, to some extent, since more heat will be generated. And that heat is lost energy which hits your gas mileage. From what I have been told, the most important thing is to make sure the transmission is not shifting constantly and driving in 3rd does that. I also understand that some people believe that driving in lower gears, at higher RPMs also puts less stress on some tranny components like the bearings. So that's a good thing. But I still don't like that the TC doesn't lock up. Would be nice to get a TCU upgrade that allows the TC to lock up in power mode, at all speeds.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
#36
HERE is a link to the thread on how to do this. As much as you may not enjoy messing with wiring, it is fairly simple to do. I did it with my first svx when I was only 16 (and I was as big of a newbie as you could be when it came to wiring in cars). Post #111 provides a decent "how-to" for wiring the manual button on the shifter to engage power mode, however you will need to refer to previous posts to view the pictures of the connector. It is as simple as removing a pin and replacing it 2 slots to the left.
Trevor Avondale, AZ 1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13 1992 LS-L Claret 178k totaled 10/26/09 1987 BMW 325is 60% of the time it works, every time |
#37
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
#38
Really? Mine only lock up over 50 mph and will stay locked to around 45 as long as the brake isn't hit. I put it back into 3 if i'm not at steady speeds of 50mph or higher.
#39
Based on the responses here, discussions I have had offline and research of old threads, here is a list of mods that most or everyone agrees are safe. They are in the order in which people believe they benefit transmission reliability in this particular car:
1. Upgrade valve bodies 2. Replace stock ATF cooler with a low flow resistance cooler 3. Upgrade TCU with unit from ecutune.com 4. Switch to synthetic ATF and do a partial drain and fill every 2-3 OCIs 5. Increase the resistance of the transmission resistor to 15-20 Ohms 6. Add switch to engage power mode I specified a low flow resistance cooler because most people agreed that heat is not the problem but lack of fluid flow and pressure is. There was strong agreement that high ATF temps were a symptom of an already failing tranny and not the cause of a failure. However, high ATF temperatures can cause other parts to fail even before the actual problem causing the heat fails itself. So, increase pressure, increase flow, change to a good ATF and/or use a good ATF additive, change the ATF regularly and keep it cool.
#40
why you drop QC from the list? it seen that's a good value mod and it's by OAB_AU
:1992 Pearl LS-L :182,000 (5/2010) – 210,000 (1/2013) :MOD :Raybestio STS front rotors :Green air filter :Aero resonator :Magnafow muffler/dual tips :RE970 tires DONATED :92 Claret SVX OTHER :07 Scion tC (wife) RIP :94 Blk Mustang GT :89 Slv 240SX |
#41
There is also opinion that #5 may do as much damage as good. Again, I was thinking that a small resistance increase would increase line pressure slightly. But there are trade-offs.
#42
#43
I got my first fluid change yesterday. The mechanic said the fluid looked and smelled good so I am cautiously optimistic. He only got 4 quarts out of it though. He had it flat on a lift. I will be going back at my next oil change and have him do a second drain and re-fill.
#44
good luck on long life for your trans.
my first svx had it rebulit 2 times and on 2nd time when i added the SmallCar kit with subaru external filter, which made it die faster (there wasn't as much info few years back). when i got the 92svx this year, i just changed the internal filter and put new oem atf. not sure i will do any mod to this trans.
#45
To my knowledge, other than maintenance, none of the six items you listed has ever been proven to add reliability to a ’96 SVX transmission under normal road use. Most items on your final list have been tested sparely, and for relatively few miles, with mixed reviews. You have taken the biggest step known and observed in increasing transmission reliability in an SVX, namely, driving a post-92 SVX. I believe that nearly everybody agrees on that. These later transmissions, when properly maintained according to Subaru, will easily approach 200,000 miles without failure. In fact, how many here have had a 96-97 transmission fail? By 96, Subaru engineers had enough years and miles to correct early reliability concerns in the SVX. That is what you risk by making changes to a car you consider a 'daily driver'. I do not believe that any advice given here regarding reliability, other than periodic fluid change, is conclusive. If you are looking to change the performance of your transmission, the 'safe' question is a different question entirely, with many opposing opinions.
Thread Tools | |
Display Modes | |
