Brake fluid
Is DOT4 OK in the SVX? I assume it is. I am wondering if the esters in the formulation will help with heat extraction and reduce rotor warping.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Re: Brake fluid
I have used fully synthetic DOT4 in SVXi since 2001.
Re: Brake fluid
DOT 4 fluid is perfectly fine. Almost all cars manufactured by 2006 used DOT 4. I have been using the DOT 4 ATE Super Blue Racing Fluid in my polo for years. It exceeds all DOT 4 requirements and has a much higher wet (396° F) and dry (536° F) boiling point. They make this fluid in both blue and gold. I alternate between them so it is easy to see when your brakes have been completely flushed by watching the color change at the caliper. It is perfectly compatible with DOT 3 and they can be combined without problems. What you don't want is the DOT5 (silicone) fluid. Incompatible with DOT3 and 4 and cannot be used with ABS systems. .
Re: Brake fluid
3600 pounds of car and aggressive driving is what warps rotors.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
Re: Brake fluid
brake fluid = rotor warping
Keith |
Thread Tools | |
Display Modes | |
