Old 09-16-2010, 10:35 PM
Manarius's Avatar
Manarius Manarius is offline
Re: dip stick
Originally Posted by kwren View Post
Then simply replace the "0" ring
Keith
Did that. Still pops up.
-Jason
-Obi Wan Kenobi
Old 09-17-2010, 12:30 PM
kwren's Avatar
kwren kwren is offline
Re: dip stick
Sorry...
Looks like plan "B"
Keith
Old 09-17-2010, 12:55 PM
Cam Cam is offline
Re: dip stick
At least the PCV valve is cheap. Only like 7 bucks if I recall. And it's not that hard to get at really. You may be able to reach it if you remove your throttle body. Don't forget to buy a new gasket if you go that route. I have never done it that way but it might be doable.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 09-17-2010, 09:08 PM
Manarius's Avatar
Re: dip stick
$3.09 + tax at Autozone for the PCV valve.
-Jason
-Obi Wan Kenobi
Old 09-20-2010, 07:26 PM
juice's Avatar
juice juice is offline
Juice
Talking Re: dip stick
where can I get the gasket I going go ahead and replce my pcv valve.
Thanks for all the help and input everybody.
Old 09-21-2010, 08:14 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: dip stick
www.subarugenuineparts.com
Old 02-06-2013, 11:13 PM
SUPER SUPER is offline
Re: dip stick
I have this same issue. How did the story end? Was the mystery solved?
