Crank Angle Sensor 2 location pleaase?
I have the following codes:
code 22 (knock sensor or circuit right side ) code 29 (Crank Angle Sensor 2) code 37 (oxygen sensor No.2) I need location and part number if any one has them? on the knock sensor what does the circuit part mean? Also, can one of these sensors trigger the others? Should I replace them in a particular order and check to see if other codes go away or are they not related at all? Thank you |
Re: Crank Angle Sensor 2 location pleaase?
Actually I only need location and how to replace for the Crank Angle sensor 2.
See, they phrased the sensors funny when they did the descriptions... Right not I want to say Crank angle sensor 2 is secondary sensor on the oil pump... But I also have a feeling it is what they refer to as the cam angle sensor as well... Either way it is the same part # for the sensor.
Tom |
According to the service manual, its the one under the alternator, right hand side when looking from the front of the car. Remove the alternator, unplug crank sensor harness, and remove 10mm bolt that holds it down. Inspect for lots of crap on the tip..... clean and replace if needed.
thank you for the response. Where can I find a part number?
Re: Crank Angle Sensor 2, price?
anyone have any idea how much I should expect to pay for crank angle sensor #2?
Crank Angle Sensor = Crankshaft position sensor???
Is the Crankshaft Position Sensor(shown in diagram) the same as the crank angle sensor#2
It should be. The location is correct but the sensor looks slightly different. Where is that diagram from? I have never seen it.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
Re: Crank Angle Sensor = Crankshaft position sensor???
[/offtopic]
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
i forgot to mention, there is a crank sensor missing in this picture. The oil pump houses two sensors. I can post pictures later if you would like. Right now mine are very visible and may help you locate them.
Please post the pictures you have. I need to find out which one is crank angle sensor #2. Thank you
The diagram I posted is from Autozone |
Thank you for the pictures. They help alot. The code i got pointed to crank angle sensor2. Why is it called #2 if there's only one crank angle sensor?
Both of those sensors work as crank sensors on the SVX. Just one of them is the same type of sensor as the cam sensor. Each crank sensor serves its own specific purpose reading its own signal relaying it back to the ECU.
The No.1 is a SVX part only. The No.2. Crank sensor, and the cam sensor are the same as the Legacy/Impressa part. Harvey.
Thread Tools | |
Display Modes | |
