Old 08-23-2002, 05:22 AM
billisa
Still, a little leak...
So, after having the cam seals and side valve cover seals replaced I still have a small, but annoying leak. Looks like one drop overnite towards the front on the engine. (based on checking the garage floor underneath the car. I am guessing the o-ring on the P/S pump... What do you think?
Old 08-23-2002, 07:17 AM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
What colour is the fluid? It'd be red if it's P/S, as we use ATF in there.
Then again, if it's red, it could be from the tranny fluid lines too.
VK
Old 08-23-2002, 10:00 PM
Ovidiu STAN Ovidiu STAN is offline
You are right. It can be very well the seal from the PS pump. I had that problem.
The oil drips slowly somewere the oil filter area.
I replaced the seal AND the bearing (less then $20 both) from the PS and now is brand new.
Good luck
