Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Engine Management
Old 06-20-2010, 06:37 AM
JDM ECU...HP Increase?
I have in my possession a JDM SVX ECU (and TCU), anyone know if it would give any gains in HP or Torque, when plugged into a USD SVX?
Old 06-20-2010, 07:46 AM
Re: JDM ECU...HP Increase?
Where did you find that? I thought they very hard to come by.
Old 06-20-2010, 08:36 AM
I don't believe so Huck. The main difference is that the JDM won't look for anything related to the EGR since JDM motors didn't have them.
Old 06-20-2010, 12:49 PM
A XT buddy Down under bought a JDM clip, I got a few things from him before he scrapped it.
I was hoping for a more definite than "I don't believe so"...anybody know for sure?
Thought I might drop it into FrankenWedge(which is currently running a 95 US-ECU...)
Old 06-20-2010, 12:52 PM
Cam Cam is offline
Test it with your butt dyno
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 06-20-2010, 12:55 PM
I may throw it in to see if I can "Feel" any difference...I don't figure it can hurt any.
Old 06-21-2010, 08:41 AM
longassname's Avatar
Just some dude.
I'll trade you a stage 1av1 for them. That will make your car faster.
Old 06-21-2010, 11:00 AM
I'll Probably take you up on that Mike...
Old 06-21-2010, 11:13 AM
My though was that the TCU would be extremely valuable to someone looking to swap in a JDM auto transmission. Especially since they are available and cheap. But even better would be to have someone reverse engineer it then offer it as an TCU upgrade option on their website. (hint, hint LAN)
Not sure if such a thing is possible, but I can hope!
Old 06-24-2010, 05:56 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Do you know what year they are from?
The JDM ECU maps are different to USDM, they are optimised for higher octane fuel. Like Nate said, no EGR. I've run a JDM car on a UK ECU which is similar to maps and didn't notice any performance difference.
The TCU won't work properly with a USDM gearbox.
Already been done.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 06-24-2010, 06:40 PM
Already been done.
JDM TCU hardware is different as well.... Needs to interpret the speed sensor signals properly. Even with JDM firmware the US TCU will not take into account the proper speed from the #1 sensor to match the #2
Old 06-24-2010, 07:02 PM
I don't recall, and Michael has them now, he might be able to cross reference the numbers to find out.
Old 06-25-2010, 03:26 AM
b3lha's Avatar
Phil & Belha
Are you sure you're not confusing it with the Euro/Aussie TCU? JDM and USDM use the same speed sensor arrangement.
I've inspected the hardware of JDM, USDM and Euro/Aussie TCUs. The JDM and USDM are almost identical. The only difference is a couple of extra components on the USDM (presumably to handle the atmospheric pressure signal).
I built some custom TCUs for Ron based on JDM firmware running on USDM hardware and they work very well.
The Euro/Aussie unit is very different. They use the different speed sensor arrangement and don't work properly with JDM/USDM firmware.
Old 06-25-2010, 04:45 AM
Positive... Even with the JDM firmware loaded into the US TCU of mine, the forward speed sensor was not reading the same as the rear
Old 06-26-2010, 07:48 AM
Just some dude.
I got the JDM ECU and TCU from Huck. They look to be 94 JDM units matching what Phil already has on his website.
