Old 08-20-2002, 06:29 AM
Kamaleon
Other pulleys?!?!
Hopefully im getting my car back this afternoon (crankshaft pulley replaced)..
Is there any other pulley that can come appart that i need to be worried about?? Im planning to do a 2000 mile trip this and next week.
P.S: i saw a little bit of oil in the outside of the rear left wheel. what do i need to fear for this time?
Old 08-25-2002, 06:45 PM
dromano's Avatar
dromano dromano is offline
The crank pulley is the only one that can fail the way yours did.
Don't know about the oil at the left rear wheel.
David
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 08-26-2002, 09:36 AM
Re: Other pulleys?!?!
The only fluid that should come near that wheel is brake fluid. Perhaps a cracked brake line (not likely because they tend to blow and you notice that FAST). Take a look at the underside of the car. Perhaps and leaking oil from the engine/tranny worked it's way down the underside of the car to the back before dripping.
Either way, a careful look under the car should give you a hint.
