Old 05-21-2010, 08:44 AM
Manarius's Avatar
Manarius Manarius is offline
Bottom of the radiator leak?
So, I noticed my car is leaking coolant. However, it appears to me that the coolant is gathered all around the bottom of the radiator. I see no trickle down source and no leaking tubes. Is this cause for radiator replacement?
-Jason
-Obi Wan Kenobi
Old 05-21-2010, 09:11 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Bottom of the radiator leak?
It can collect there from seepage from many places, including the internal fins. The easiest way to find the source is to pressurize the system with a tester, or if youre careful.... get the engine hot and look for the leak after you shut it off.
Old 05-21-2010, 11:49 AM
redlightningsvx's Avatar
Collision Refinishing Tech
How is your bottom hose?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 05-21-2010, 01:12 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
the radiator can also leak from the two locator pins in the bottom tank if the pins have been cracked where they meet the tank.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-21-2010, 11:02 PM
Manarius's Avatar
Bottom hose appears dirty but fine. Along the bottom of the radiator, it definitely looks like there is coolant collecting there. I can't tell from where though. It doesn't look like it's coming from the top, from the middle, or from a certain side. I just know it collects enough to make a small puddle under my car every time I park and it stops leaking after the pressure is out of the system (or at least it doesn't leak enough to drip).
-Bill
The leaking started within the past week or so. The radiator appears to be fairly new. So, I'm not real sure.
-Jason
-Obi Wan Kenobi
