Old 05-14-2010, 08:04 AM
Manarius's Avatar
Manarius Manarius is offline
Two questions
All right, so I haven't posted a thread in a while so bear with me:
I was listening to NPR's Car Talk the other day and someone called in and said that her car with like 125k miles was idling very poorly at cold and was missing under acceleration. They suggested that she bring her car to a shop equipped with a motorvac system. The motorvac system supposedly bypasses the fuel pump and basically runs a very rich detergent through the fuel rails and injectors to clean them out. My car is suffering from the same problem (missing, idles bad at cold..even warm too).
Would this be a worthwhile venture for me to find a place that has this system and have it done to my car? I just clicked over 189k miles. Maybe it's just me and having seen Shell commercials, but it seems like ever since I put that Shell gas in, the car runs just a little bit better. However, I could just be full of it.
Now, my other question: Whenever I turn the key to the on position, I hear the fuel pump come on. The fuel pump and lines seem to make an awful lot of gurgling noises for a little while until the system is pressurized. Is this a sign of a fuel pump saying goodbye? If so, could this be contributing to the fact that my car runs poorly?
Any help would be much appreciated.
-Jason
-Obi Wan Kenobi
Old 05-14-2010, 09:08 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Two questions
You could first use a very high quality COMPLETE fuel system cleaner (from a bottle), then replace the fuel filter, and see if your condition improves. If so, maybe its worth it.
I have noticed gurgling sounds from my pump as well but it has never affected the operation of my car. You can test the fuel pressure very easily.
If you have never done it, your engine seems like its a prime candidate for Seafoam, or removal and cleaning of the entire intake system, as our cars inhale and subsequently get gunked up with an ungodly amount of soot and grime, both thru the PCV system and the EGR. I screamed in horror when I saw mine
Old 05-14-2010, 09:28 AM
dcarrb dcarrb is offline
Re: Two questions
Hey, I've been a "Car Talk" fan for years (but I don't remember the caller you mentioned). Seems to me the guys generally tend to suggest detergents or additives—if they do at all—as a shoulder-shrug "can't hurt" first step to troubleshooting. I personally believe that a car that's consistently idling poorly and missing has an electrical or mechanical problem that isn't likely to be helped by any sort of additive or cleaner.
I understand that the intake of an SVX can get pretty gunky and suppose that might impede performance ever-so-slightly, but I need someone to explain why this would cause a stumble or miss.
If my cars are typical, the fuel system gurgling you hear is normal.
dcb
Old 05-14-2010, 10:05 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Two questions
dcb
My first thought would be the Idle Air control, the actuator that opens and closes to allow idle while the butterfly valve is closed. Gunk causes the actuator to not open or close properly, which will screw with idling. This same gunk will also coat intake and exhaust valves, causing them to not seat right, leading to compression leakage from the cylinder, which makes the engine idle rough due to misfire. Even slight misfiring screws with fuel trim, which will also make the car idle/run weird and substantially degrade performance.
I invite you to pull the small EGR temp sensor off and see whats in there. Even the big plastic intake tube gets really nasty as much of the PCV vapors are pulled directly into it (all those hoses attached suck in crankcase fumes and cylinder blow-by)..... which then coat our butterfly valves and the rest of the intake runners and attached components.
Many here have used the Seafoam with very positive results, it takes time to do it right but from what I have read the benefits are worth the effort.
Old 05-14-2010, 01:07 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: Two questions
My fuel pump is doing the same thing. Gurgling and buzzing every so often but with no adverse effects. Couldn't hurt to replace it right?
Old 05-14-2010, 02:23 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: Two questions
Have you guys ever replaced the fuel filter?
Old 05-14-2010, 03:10 PM
Manarius's Avatar
Re: Two questions
I would say that the fuel filter has about 8000 miles.
-Jason
-Obi Wan Kenobi
Old 05-14-2010, 03:25 PM
benebob's Avatar
Re: Two questions
I thought I remebered that. How does the strainer look like on the fuel pick up?
