Old 05-05-2010, 07:23 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
pics of the new beast,
here are some newer pics on the new evo x
we just finished the /wheel suspension package
suspension is BC coilovers
wheels are rota grids 18X9.5 with yoko's 265/35/18
this is my time slip from last friday night
bext time was 12.55 @ 108 fully loaded on pump gas
only modifications are a TBE, Intake , Reflash every thing else is 100% stock on the engine side
the car is also verry heavy at 3,500 lbs
some race gas, shed some weight and a better 60' time it should be into the hi 11s on the stock turbo with just minor bolt ons
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 05-05-2010, 09:35 AM
Re: pics of the new beast,
That is one sexy car Solar, nice figures on a heavy 4cyl car.
No cams yet?
P.S: I could use your rear diffuser for my next mod
Old 05-05-2010, 10:06 AM
No cams yet?
no cams there pretty pricey for the amount of power you get from them, for the same price you might as well upgrade the turbo with the basic bolt on turbo upgrade puts you around 550 hp range with the Fp red,
the reflash made the most hp almost 80 more hp and redline increased to almost 8,000 rpm anything above that requirese cams
the most fun is in the handling department with its super AWD and Yaw control for the rear diff
Old 05-06-2010, 10:51 AM
Really? A reflash = + 80hp? Mannnnn, wish the case was similar for the SVX.
Old 05-06-2010, 11:28 AM
NeedForSpeed NeedForSpeed is offline
Nice EVO
Could you post, 'what exactly is' super AWD and Yaw control?
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 05-06-2010, 11:43 AM
Ron, you should watch that episode of Top Gear where they compare Solar's beast to the hatchback STi.
I know exactly what Super AWD and Yaw Control are
Old 05-06-2010, 11:49 AM
Did I miss a link to Top Gear?
I've read and seen mentioned the Mitsu Super AWD and Yaw Control, but can't say that I know exactly what it is or how it works.
Would like to know more
Old 05-06-2010, 12:31 PM
HERE
Old 05-06-2010, 01:22 PM
[edit] Active Center Differential (ACD)
Active Center Differential incorporates an electronically-controlled hydraulic multi-plate clutch. The system optimizes clutch cover clamp load for different driving conditions, regulating the differential limiting action between free and locked states to optimize front/rear wheel torque split and thereby producing the best balance between traction and steering response.[1]
[edit] Active Yaw Control (AYC)
Active Yaw Control uses a torque transfer mechanism in the rear differential to control rear wheel torque differential for different driving conditions and so limit the yaw moment that acts on the vehicle body and enhance cornering performance. AYC also acts like a limited slip differential by suppressing rear wheel slip to improve traction. In its latest form, AYC now features yaw rate feedback control using a yaw rate sensor and also gains braking force control. Accurately determining the cornering dynamics on a realtime basis, the system operates to control vehicle behavior through corners and realize vehicle behavior that more closely mirrors driver intent.[1]
Old 05-06-2010, 01:25 PM
http://www.youtube.com/watch?v=tGAjT...eature=related
this explains how the ASC program works also,
silver that exlpains most of it, =>
http://www.youtube.com/watch?v=S4CfWdoSOTk&feature=fvsr
Old 05-06-2010, 01:28 PM
Thanks for the reply ,
On the Active Center Differential, what is the range of torque transfer, between free and locked?
The AYC is also electric? What is the range of transfer of torque IN THE REAR DIFF, from one side to the other?
Old 05-06-2010, 01:52 PM
i not sure on the first one, i honestly dont know
the AYC usses hydraulic fluid there is a seperate resavoir that sits in the trunk of the car
