Resonator
I took my car to the exhaust shop today to get rid of my rattle. He took off a few heat shields and cut out the rear resinator and put in a straight pipe. The car seems really wierd now, sluggish. I'm assuming he shouldn't have taken it off. He said that is was rattling and shouldn't make a big difference, but I notice it bigtime! I want it to not rattle and to be as it was before. Where can I get a new rear resonator? I looked on subaruparts.com, and they are like $300. Any where else to get one cheaper?
1992 SVX LS-L: For sale 1995 Lexus SC400- Lexta Z |
Re: Resinator
I have never heard of a car running "weird" due to the removal of the resonator in the exhaust system. They are typically there only to reduce the exhaust db level or to tailor the exhaust note. Granted N/A engines need a certain amount of back pressure but with cats and the muffler there should be an ample supply. Check to see if the O2 sensors or wiring was damaged. Do you have a CEL illuminated?
Re: Resinator
It could be a pleciebo effect.
Re: Resinator
No CEL, and I just put in brand new O2 sensors a few weeks ago. At that time, I also did the seafoam in the intake, cleaned the MAF, and fixed my PS leak. I just put new plugs in it on Saturday as well. Has been running awesome! Then, I just drove it from the shop, back to work. I'll take it out after work and see if anything changed. But it seemed really sluggish to me. Changed the power completely.
I found a high flow resonator on MotorsportsWarehouse.com. Does anyone have one of these? Did it change the performance at all? Should I try reseting my ECU and see if that helps? Redlightining- What is the pleciebo effect?
Re: Resinator
Nah, from what I had explained to me, you need to have an expansion where there was one to begin with. If there was a resenator there before, put an aftermarket one there now or else you will hurt performance. Aftermarket is cheaper so that's what I would go with.
Also, motorsport warehouse is really expensive.. Jus look for aftermarket parts on or partstrain. And a pleciebo effect means it's all in your head..
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k At least it's going down..
Re: Resinator
I'm sorry Freeman but in my fairly vast mechanical experience/knowledge, I have to completely disagree with you. |
Re: Resinator
Hey, thats just what I gathered from OT saying it.. If that man said he was Jesus and has toenails of gold, I'd believe him.
Re: Resinator
Freeman is right. The 'Resonator' is a vital piece of the exhaust system. It acts as the expansion area for the gas plug from the cylinder to drop pressure in. It also is an expansion point for the sonic wave to reflect back to the cylinder as a negative pressure. Without it the engine looses a lot of torque. It should be replaced with a Resonator of the equivalent volume. Harvey.
Re: Resinator
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
Re: Resinator
The easiest way to kill the engine power is to change the front end of the exhaust system. From the resonator back, you can do what ever you want. May not be apparent, but the standard system is the best you can use, for the standard cams. Harvey.
Re: Resinator
I've kinda based my exhaust's design around the fact that I'll need to keep air flow where it once was..
See? Yeah I've got MS Paint skillz..
Re: Resinator
Re: Resinator
that should make it really easy, right?
Re: Resinator
Lego's, clay, and the other half of the glue I didn't eat!
Re: Resinator
that would explain why when my resonator is rattling i have **** for power but once it stops ratting its like V-tec kicks in lol
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... |
Thread Tools | |
Display Modes | |
