Old 05-05-2010, 02:28 PM
Re: Transmission input
Originally Posted by gbianchi View Post
Thank you Harvey, Thank you Trevor, picture tells alot, I think I can do this, so I'm gona do it, any reason to not drive it the way it is, a little bit???........................G
You have done some great work and should be proud of yourself.
OK to drive the car, provided you keep the fault in mind and note any further deterioration in performance. Try not to cause the torque convertor to slip for any length of time, due to no lock up function. There should be an approximately 500 RPM variation registered on the tacho. with convertor fully slipping.
You have a situation whereby, something is not happening, rather than something occurring which will cause damage. No need to panic.
Cheers, Trevor.
Old 05-06-2010, 07:54 PM
gbianchi gbianchi is offline
Thanks again, all this automatic stuff is new to me, I'm a manual guy, but love these SVX.
So as for driving it, no burn outs, and just cruise around with a light right foot?? To keep the tc from silipping alot? The oring at the end of the tranny check/fill pipe is drooling on the left exhaust so I need to drain the pan to fix that and while I'm at it I'll get after that b soleinoid, thanks again, everyone enjoy there SVX's......................G
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
06 Subaru legacy gt limited.
Old 05-06-2010, 10:01 PM
Yes No burn outs....... No need to worry about the Torque converter slipping a lot, it is suppose to do that. The Lock-up clutch is really for.
The leak at the filler tube is just an O ring. If you are going to pull the pan to do the solenoid, you may as well replace the screen filter.
Old 05-06-2010, 10:12 PM
Your thanks are very much appreciated and make posting advice worthwhile and enjoyable.
Sincerely, Trevor.
Old 05-07-2010, 02:22 PM
All advice given me is greatly appreciated, I really enjoy learning and doing and getting results that are positive. Never stop learning and if so inclined doing, TTFN.........G
92legacywagon"snow"
84Brat"huey"
