Old 04-10-2010, 06:32 PM
ABSVX ABSVX is offline
Send a message via Skype™ to ABSVX
Weird Front-end Behaviour when Reversing
I just had sway bar links and a front right wheel bearing replaced, and when I backed up and turned, my front wheels "jerked/jumped" sideways a couple of times accompanied by a mild crack/bang each time they jumped (tires are bad and one was soft, but they are matched on the front, different on the rear but all 225/50/16's; 4 replacements are on order!) Drove away and tried to reproduce this is a parking lot and got the same symptom very mildly, then it seemed to go away, but it's back today slightly. The transmission isn't 100% (hard 1/2 shift and maybe a slip in 3), but the local shop says it's not bad; diffs are supposed to be 100%. Transmission will go under the knife soon, but I want to make sure I do anything else that needs doing at the same time.
Can anyone suggest the reason for the strange sideways jump and sound??
Thanks! Mike
'94 Barcelona LSi AWD 127K Km's
Old 04-10-2010, 06:42 PM
Re: Weird Front-end Behaviour when Reversing
The quality of the work you had done regarding the bearing, is very suspect.
