Old 08-14-2002, 12:22 PM
clarkerussell
Heat shield maybe?
I have an annoying rattle that sounds like a heat shield is possibly lose. It's at about 1300 RPM, and then goes away. I have not had it on a lift yet, so asking this is porbably premature. Is there a common problem with heat shields? I ask because if there is I can start there. Thanks.
Clarke
Old 08-14-2002, 12:40 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Heat shield maybe?
Clarke
Yes. Heat shields are a common problem. There is also a "resonator" between the Y pipe and the rear muffler. It has a tendency to deteriorate inside and cause a "buzzing" sound (like a coffee can full of bumble bees). Many have cut the resonator out and replaced it with straight pipe, since replacement is in the 500 buckeroonie range.
Randy Johnson
Mike Davis -- at Reading VI
Old 08-14-2002, 01:05 PM
clarkerussell
Thanks
Are the shields bolted, or tack welded in place? Thanks.
Clarke
Old 08-14-2002, 10:22 PM
DWayne2910
Clarke:
The heat shields (2) are under the front floorboards
and are welded. The welds tend to rust out and
shields break loose and then rattle as pipes vibrate
at certain RPM ranges. Common fix (at least at my
Suby dealer) is removal. It's apparently common on
most Subies, not just SVX.
Dan
Old 08-14-2002, 10:48 PM
Aredubjay's Avatar
Originally posted by DWayne2910
Clarke:
Dan
Ah, I just remembered another "rattle" in the heat shields. The Y-pipe shields tend to pick up and store small rocks. Rocks caught in the heat shields will also cause a rattle or buzz. I had the y-pipe shields removed and several stones fell out.
A word of caution about having the heat shields removed: don't be parking in any fields with high grass (especially in dry season), it could cause a fire. I park in my yard and the area where my car sits, and the heat shields have been removed, turns yellow.
Randy Johnson
Old 08-15-2002, 12:55 AM
FlagstaffSVX's Avatar
FlagstaffSVX FlagstaffSVX is offline
Jedi Member
My car has a buzzing noise that happens at low RPM's (around 1300-1700) and I've narrowed it down to the drivers side cat. Apparently the baffle plates get old and rattle around but when there is more pressure from more RPM's the rattling noise stops.
Just my $0.02...
-Craig Lowthorp, Flagstaff AZ
'92 LS-L, Black on White, 136k SOLD
'92 LS-L, Black on Silver, 120k SOLD
'01 Legacy Outback, White,
Old 08-15-2002, 09:25 AM
Aredubjay's Avatar
Just my $0.02...
That's not $0.02. That's about $400.00 --- per cat! That's why I didn't mention it. Being an "avoidist" I would rather ignore the expensive fixes and hope they go away.
Randy Johnson
Old 08-18-2002, 12:40 AM
htyei's Avatar
htyei htyei is offline
SVX Animated Icon Guy!
Send a message via ICQ to htyei Send a message via AIM to htyei Send a message via Yahoo to htyei
If the car has every bottomed out before, you may also have dents in the Y section of the exhaust system.
Thats waht happened to me, and my insulation had deteriorated to nothing.
I tried banging the y shielding, and moving the insulation near metal contact points, but rattling came back after a week.
If it is the Y-shields that ardub described, just go to Home Depot, buy some rustproof, steel strips of metal and clamp it between pipe and heatshield.
I effected that fix last summer, and its been golden since.
Henry Yei
htyei@svxwrx.com
1992 Dark Teal LS-L w/o spoiler "OLIVIA"
http://www.svxwrx.com
Old 08-19-2002, 06:30 AM
clarkerussell
Fixed..
One of the heat shields must have hit something bcause it was crumpled back a few inches. The shield was touching the exhaust and making a horrible rattleing noise. I just bent it back and all is now better. Thanks.
