Old 04-06-2010, 12:06 PM
Drivers side rear window not working
My driverside rear window doesnt work today.
Just stopped working.
Hitting switch on drivers door does nothing, same with from rear seat.
I get no noise at all, like its not plugged in.
Where is the relay switch thing for the driverside rear window?
Anyone got a part number?
Any other suggestions for what may cause this?
Old 04-06-2010, 04:21 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: Drivers side rear window not working
Hey! Mines done the same thing since I first got it. Doesn't react to any of the switches and you can't even hear any motor or movement right?
We're broken rear drivers side window buddies!
Old 04-06-2010, 04:32 PM
correct, no sound at all. not even trying to move. worked fine yesterday. I am assuming its not fuse related seeing the rest of the windows work fine.
I just need to know where to start looking to fix the problem. i dont care if i have to replace the entire rear power window actuator, I just want it fixed.
Well if someone suggests a fix ill go for it and try it and let you know, then we can be happy working rear window buddies.
Old 04-06-2010, 04:50 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Sometimes they get stuck if they haven't been used for a while. Try and move it with your hand or a suction cup while pressing the button.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 04-06-2010, 06:12 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Easy way to go:
Check for 12 volts at the connector on the motor when either window switch is pressed. 12 volt signal present means the motor is stuck or dead, no 12 volts means you need to check your connections between the main switch and the motor.
Old 04-06-2010, 07:32 PM
window was fine yesterday, i have been rolling them up and down without issue for the last 3 weeks. So i don't think its stuck.
Ok I would love to test the line into the rear window motor.
Where is it and how do I get to it?
Old 04-07-2010, 04:37 PM
Do i need to remove the back seat bottom to remove the rear seat plastic trim stuff that is below the window?
Old 04-07-2010, 04:43 PM
sabin sabin is offline
Banned
yes you need to remove the back seat to get to it
Old 04-07-2010, 06:05 PM
ok, looks like this project is getting put off until sunday when we do the stereo and alarm install.
I'll have to take the back seat out and them cover panels off to do the rear speakers anyways.
Sunday is going to suck, got to figure out whats wrong with power locks, wire up alarm with keyless entry, install new speakers all around, figure out whats going on with rear driverside window, and then put it all back together.
