Old 03-30-2010, 06:43 AM
NiftySVX NiftySVX is offline
Quick Help Needed For Radio
Hey all, I can't access the svxdc install guide here at work and have an opportunity to get a pioneer x910bt for a great price, it is 6.2 in deep, and I need to know if it will fit and if the door will close, does anyone know?
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 03-30-2010, 08:11 AM
sowise sowise is offline
Re: Quick Help Needed For Radio
crutchfield website says yes but it is a modified fit, only they don't say what modification is required but their site will say when one doesn't fit. Good luck and remember you can always put it up for sale if you change your mind.
Edit: Maybe they do say what is needed here is the installation instructions:
Installation Details
Modified Fit - Requires Modification
Installation Details for your 1992 SVX
» To install this product, you’ll have to modify your vehicle.
» Use the brackets that came with your factory stereo to install your new receiver.
» An installation kit is not required to install your new receiver.
» A wiring harness is not available. You will need to splice into the factory wires.
Old 03-30-2010, 10:27 AM
Pav625's Avatar
Pav625 Pav625 is offline
... a work in progress
That's the same head unit I put in mine, found a wiring harness from a guy online along with great instructions, putting it all back together wasn't the easiest, but the result was def worth while!
This is the site I used: http://ae64.com/SVXharness.htm
Old 03-30-2010, 11:44 AM
Yes, that is svxdc's website. He's the one who makes all the harnesses for the SVX.
Sowise, Crutchfield is probably going to say you have to modify any deck you put in. Due to the radio cage, you have to take the mounting "sleeve" off of any deck you put in. Not really any true modification. Also, no offense, but I really don't trust what any website says about the SVX. I trust the people who actually have done installs/work on the SVX. Not trying to blast you at all (hope I don't come off that way), just pointing out the info.
Old 03-30-2010, 11:46 AM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
I'm outraged! My site is a serious, technical site, not some pr0n site
... will [a Pioneer AVIC-X910BT, 6.2" deep] fit and if the door will close ... ?
Yes. The interior of the cage is 6.625" deep. Some of the HU's 6.2" depth will be extending out past the front edge of the cage, so you should be good there.
Here's a good picture of the front from Crutchfield's (click on these thumbnails):
Rear:
A/V harness:
Pioneer's AVIC-X910BT product page (with links to user and installation manuals).
It looks like you'll need to notch the cage for the HU's USB cable. The other sockets might be so close to the bottom that you'll need to remove the entire rear of the cage (easy to do -- just drill out the four spot welds). The opening on the cage's rear frame is about 3/8" (9mm) smaller on each side than the outer dimensions of the cage. Picture:
As for being able to close the SVX's audio cover door, the face on that Alpine looks to be fairly low-profile. The volume knob doesn't appear to protrude very far, and it's not at the bottom edge (where the knobs on some WRX radios cause clearance issues with the rear of the door).
Originally Posted by sowise View Post
[Crutchfield's installation instructions say]:
Of course they say there isn't a harness available -- they don't know about mine
I've run into this before. They're a bit conservative on the maximum depth they think will fit in the SVX cage. They don't want to have the back edge of any of the HU's wire harness plugs protrude beyond the back. I think they want to allow enough clearance for you to fold the wires down/up/sideways before they exit the rear of the cage.
In practice, there's from 1 to 2" space behind the bottom half of the cage, so most HUs don't have a problem.
Now when a HU has a massive A/V harness (with lots of RCA jacks), like this AVIC, it will take some effort to stuff all of that into the openings behind and/or under the rear of the cage.
Lately I've been recommending people tie a pull-string to a harness, thread the loose end out to either the driver's or passenger foot well. As you slide the cage into the dash, pull the string to retract all of the harness' slack into the rear openings (so the wires don't bunch up behind the cage and get sliced).
You might also want to preemptively tape up all of the SVX's sharp edges back there.
See my SVX Audio Install guide for more information and pictures.
See this post for some concerns about a HU with a fold-down face.
David C.
Old 03-30-2010, 12:37 PM
I couldn't access SVXdc's site from work either so I went to crutchfield. Some sites and most all of the pictures posted here at the SVXWN won't display due to work I could swear the last time I was on their site it actually had some that were direct fit, won't fit, and modified fit but now I went back and all of them pretty much say modified fit. However there are a few Double Din Decks that definitely won't work and some of the flip screens too. but point taken just have a hard time leaving a guy hanging for a response, so give the best info I can with what I've got. It is a take it or leave it option for them.
Old 03-30-2010, 12:42 PM
Very true
Just trying to give better info that I can by adding onto what you had said. Just if some other person is searching in the future and comes across this or someone else sees this thread, we don't want them to fully rely on Crutchfield
