Old 09-01-2009, 09:34 AM
Wanted: Watefall grille in any condition
I need a waterfall grille in any condition. It can be yellowed, scratched, cracked, etc.
I just need one to cut apart to see how the inside is made and to take interior measurements in preparation for a potential modification.
PM me or send me an email.
Thanks
Old 09-01-2009, 02:18 PM
Thumbs up Re: Wanted: Watefall grille in any condition
John, this sounds like an interesting project. I wish you luck with it. I had thought of using the waterfall grille as a "frame" to make a new style grille, just never got around to it.
Keep us posted once you get one
Old 09-01-2009, 05:02 PM
Will the new project with the grill make hambergers or steaks?
Old 09-02-2009, 07:02 PM
immortal_suby's Avatar
Thread Killah
Only if the mod is filling it with wine and installing a tap.
Locker Link
2015 BRZ Limited 6MT
Old 09-02-2009, 07:16 PM
subeman90's Avatar
Soobologist
maybe he is going "Mercury" on us?!
15 OBW premium w/eyesight
Old 09-03-2009, 01:05 AM
This is John, not Ron.
Ron's the only one on the forum with a genuine waterfall rear spoiler.
Old 09-03-2009, 03:08 AM
Thanks
You can remove the outside transparent cover my method of heating similar to the headlights and corners. And it is hollow from the inside, you can just take approximate measurements from the outside...
Old 09-03-2009, 07:57 AM
ZMan's Avatar
ZMan ZMan is offline
I just measured my spare grille, and measuring at the bottom, I get a depth of 2 15/16 and it measures the same across the entire width.
So allowing for the thickness of the plastic, your light bar at 2.25 will just fit. - getting access to the inside is the problem.
I used the heat method on front corner lights, but not on a grille.
Maybe a number of carefully drilled then connected 3/8 inch holes either on each end or across the back will work or slotted with a Dremel.
In any case you will have to be very carefull when doing any of this, including removing your grille from the car - never force anything! Good Luck - Ed
Old 09-10-2009, 05:11 PM
Grille no longer needed.
sowise contacted me and sent it to me at no cost; even paid the shipping!
stay tuned...
