Old 10-18-2008, 01:05 PM
Dominus's Avatar
Dominus Dominus is offline
Homo Sapien Superior
Removing Window Tint
So I finally got around to removing the cracked and bubbling window tinting on my rear window. It's been like this since I bought it, but I knew it was going to be such a hassle to remove it that I only removed the tinting on the side windows and left the back.
Now that I have started it I see why I was so hesitant to try and remove it. Being as cracked and brittle as it is, the tint will only come off in small pieces. The defroster lines don't help. I have been very careful around them however.
After working on it off and on for two day I now have most of the rear window cleared of tint. The only part remaining is the very top where it has all those little black dots. This part is even harder to clean off though as all those little dots make the tint break off into tiny little pieces about this big < >. I can't seem to remove it faster than this and can't scraped it as this will remove the little dots.
Any advice?
“Veni, Vidi, Vici.”
Old 10-18-2008, 01:35 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Re: Removing Window Tint
Get a spray bottle and mix warm water with amonnia. Spray on and let it soak for 10 minutes or so, then wipe with a cotton fiber cloth. It will come off much easier. Cover the rear deck with a garbage bag, so you dont get it all wet with the spray. Its not an easy job, or fun, but when its done, your like wow, I have a clean clear window. I did it on my wrecked 96 when I got it, cause the tint was so bad you could barely see on a rainy foggy night.
Dan
1995 POLO LSI 76K MILES SOLD
Old 10-20-2008, 07:22 PM
mysvxrocks's Avatar
mysvxrocks mysvxrocks is offline
Im REALLY addicted! CANT STOP!
Send a message via MSN to mysvxrocks Send a message via Yahoo to mysvxrocks
Gah, I need to do this to my 92 as well.... I dont want to do it, as I know it will just SUCK. But its so hard to see out that window.. Once you let it soak in the mixture, what is the best way to start removing the tint?
D.J. McPhee
2006 Infra-Red Ford Focus ZX3 ~ 67k
No longer SVX'n, Ill always miss them!
1995 Polo Green LS-i ~ 95k
1992 Dark Teal LS-L ~ 145k (04/91) #2231
Old 10-20-2008, 07:29 PM
Once it soaks, I used a plastic putty knife to scrape it off. It helps to do it on a warm sunny day so the sun helps to heat and soften the tint.
Old 10-20-2008, 07:32 PM
mysvxrocks's Avatar
I was thinking of having it in our garage, and setting up a heat dish heater pointing towards the window, as a warm, sunny day, wont come again in WA for about 7 months, LOL
D.J. McPhee
