Old 05-25-2016, 07:21 AM
Billsy Billsy is offline
Re: glass headlights
the Australian ones are Glass also.
Old 05-25-2016, 12:06 PM
Jvan Jvan is offline
Glad to see that this thread has new life. Want to see the "how to" if someone can help post it.
Old 05-25-2016, 01:06 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Jvan,
I will send to you - what is your email address.
I am based in New Zealand and we also get glass headlights, but in NZ we do not get the fog lights.
So I picked up 3 versions of the lights JPN/USA/NZ - the other 2 have got fog lights fitted, the reflectors in both have same p/n - the only thing that makes them LHD/RHD is the plastic lens.
I just recently picked up the motorized versions, going to use the fogs in these shortly.
regards
Stephen Surtees
Old 05-26-2016, 05:38 AM
theflystyle's Avatar
I have a pair of glass EDM headlamp assemblies. They have been sitting on a shelf for sometime now. Maybe this thread will rejunivate my interest in getting them installed. I have the switch but dont think I will be using it. I think I will just switch the glass over to the USDM assembly.
1994 SVX LSi
2008 Legacy 3.0R
Old 05-26-2016, 07:43 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Keep us informed if you do this.
"Peace is the flower of justice."
Old 05-29-2016, 12:36 AM
AlcyoneSVX's Avatar
Alcyone Silver Contributor
My Blanca has european glass headlights. All I did was change the connectors for the low and high beams. I didn't connect the levelers (I adjusted them by hand). I also don't have the foglights. I actually prefer the look of them with the chrome blank. The bulbs are different from the USDM. H1 for the lows, and H3 for the highs.
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
Old 05-29-2016, 07:39 AM
DallasSVX92's Avatar
DallasSVX92 DallasSVX92 is offline
They look great like that. Also, I had sent you a PM a while back about having the same wheels as your Ebony. I need to take some nice pics when the weather clears up and show you.
Old 05-30-2016, 11:30 PM
AlcyoneSVX's Avatar
I look forward to seeing pics of you SVX!
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
