Old 05-08-2008, 12:38 PM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
Need Pinion Gear!!!
I need the ring and pinion gears from a stock 4EAT to replace my broken ones. It's no longer availible through any subaru part dealers. they are labeled #1 in the diagram. PLEASE HELP ASAP!!!
-Nate
'92 LS-L Pearlie
Old 05-08-2008, 01:23 PM
Though I am sure we have one around, have you tried Jackie at Annapolis Subaru? YT and I order from her all of the time. SVXWN gets a discount...
I will check with YT to see what we have in the shop.
Old 05-08-2008, 01:46 PM
Sir. Nate's Avatar
SVXtreme
I did a little research and subaru parts.com has them for a 1997, would this be the same for a 1992? Also, what about a 4.11 trans makes it a 4.11? Is it just the ring and pinion in the front gearbox? Thanks Mike, It'd be awesome if you guys had a good used set in your shop.
-Nate
'92 LS-L Pearlie
Old 05-08-2008, 04:27 PM
Yea we have some here if you need it. And yes, just the ring and pinion decide the final drive ratio, be it 3.545, 3.70. 3.90, 4.11, or 4.444
Old 05-08-2008, 04:33 PM
Sir. Nate's Avatar
SVXtreme
Sweet, what ratios do you have on hand? And what prices as well?
-Nate
'92 LS-L Pearlie
Old 05-08-2008, 04:39 PM
we only have the stock ratio of 3.545. R&P w/ a front diff housing is $275 shipped
Old 05-08-2008, 04:48 PM
Sir. Nate's Avatar
SVXtreme
I don't need the diff housing, would you sell the gears by themselves?
-Nate
'92 LS-L Pearlie
Old 05-08-2008, 05:57 PM
sure, but it is much easier to keep the backlash and pinion depth for this diff rather than have to pre-load the bearings again set the pinion depth and backlash it.... Up to you, either way its the same price as I will just scrap the housing after I remove the gears
Old 05-08-2008, 06:09 PM
Sir. Nate's Avatar
SVXtreme
Yeah, you're right. I'll hit the easy button. PM sent.
-Nate
'92 LS-L Pearlie
