Old 04-12-2008, 01:19 PM
Schralper's Avatar
Schralper Schralper is offline
does an ej1.8 fit an loyale?
does the 1.8 liter ej18 subaru impreza or legacy engine fit a loyale w/ 1.8?
Or is that another type?
what can i say, i'm a subbie dork
WFO!
http://www.cardomain.com/id/Schralper
"You all laugh cuz I'm different
I laught cuz you're all the same."
Old 04-12-2008, 04:49 PM
crazyhorse's Avatar
242,000 mi on oem trans
Fit, yes. A direct swap, no.
It will fit between the rails & reasonably bolt into the chassis. That said, you'll need an EJ series transmission, or adapter plate. The wiring is TOTALLY different, so you'll need the ECU & engine harness from the donor car as well.
Your best bet is to do some soul searching over at www.ultimatesubaru.org The EJ into EA (Loyale) swap is well documented. I'm sure you'll find all the info you need there, if not they'll help you find it.
"42"
Current Stable By Age:
Old 04-12-2008, 08:17 PM
Schralper's Avatar
thanx
WFO!
Old 04-13-2008, 04:04 PM
Yeah, like Paul said, check out the Retrofit forums at ultimatesubaru
Personally, if I was going to go through all of the work to do an EA -> EJ swap, I'd put in a ej22 or ej25...
Old 04-13-2008, 11:34 PM
Hondasucks's Avatar
Subaru Technician
Yeah, +1 on the 2.2 at least, 140 HP vs. 110, and I don't think the fuel mileage will be all that different.
1986 VW Jetta
